Do all these trucks come stock with a mag drain plug? I found it very handy- once I pulled it out and wiped it off I just stuck it to the oil pan- no more worry about losing it.
They better not, every oil change I've brought out a paper tower to place the plug in so i dont lose it.
If i find out it woulda stuck to the oil pan, It may become a subject to my slingshot next oil change.
Yes Chase they're all magnetic (except for Parklands )
The only down side to this is when you become so used to it that when you change the oil on your daughters jeep you stick the drain plug on the oil pan only to watch it drop in the friggin drain pan because hers isn't magnetic.
