Starter not engaging like I have a short or something loose...
Old 08-19-2002, 07:09 PM
HukeOKC's Avatar
HukeOKC
HukeOKC is offline
95 F-150 I-6
This problem has gradually gotten worse with time. I get in the truck, turn the ignition and it doesn't do anything. The lights work, dash lights and gauges work but the engine isn't cranking. If I hold the key in the start position and press and release the clutch I can hear a clicking with each push on the clutch and usually it is during one of those pushes on the clutch or turning the key over and over that the engine cranks and it starts right up. Once I can get the starter to turn the engine over I have no problem. This problem is usually worse when the truck has sat for a few hours and gets cold. I have cleaned the battery terminals and posts but that hasn't fixed it.
Any ideas would be greatly appreciated. Thanks in advance.
Old 08-19-2002, 08:10 PM
kioolt's Avatar
kioolt
kioolt is offline
I had a problem where the solenoid wire on the starter had a coroded connection. Cleaned the connection and it solved the problem.
Old 08-19-2002, 08:24 PM
Mike W's Avatar
Mike W
Mike W is offline
Also, check with a test light or voltmeter on the solinoid to see if it gets 12v when you push in the clutch and turn the key. Maybe the clutch interlock switch is intermittent.
Old 08-19-2002, 09:02 PM
HukeOKC's Avatar
HukeOKC
HukeOKC is offline
I'll try those and see what I find.
Also, I might add that this problem doesn't happen every time I try to start the truck. It seems like a corrosion problem but if I can't find any significant corrosion, should I have the solenoid tested?
Old 08-19-2002, 11:34 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
How about......a neutral safety switch acting up.
That would explain the position of the clutch with the starter intermittently working.
Maybe loop a wire on the neutral switch so it acts as it would guaranteed in neutral.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old 08-20-2002, 11:02 PM
samhihn's Avatar
samhihn
samhihn is offline
Had a similar problem with my 93 explorer. I ended up replacing the battery cables....they were corroded on the inside of the insulation and there was too much resistance to allow enough current to turn the motor.
Old 08-21-2002, 07:52 PM
fireboy's Avatar
fireboy
fireboy is offline
Just fixed mine last week. The starter cable had corroded and broke off. Put on a new cable and was fine.
Old 08-21-2002, 08:09 PM
Mike W's Avatar
Mike W
Mike W is offline
Saw a Ch**vy yesterday that was leaking acid out of those stupid side mounted terminals. Battery cable was corroded away and the threads on the terminal were almost destroyed. Glad Ford didn't do that.
Old 08-22-2002, 02:42 PM
HukeOKC's Avatar
HukeOKC
HukeOKC is offline
Well it turned out to be the starter solenoid. I sure do appreciate all the input I got on this from you all. But I replaced it and haven't had the problem since. Thanks again for all the help.
Old 08-23-2002, 02:08 PM
paulmal's Avatar
paulmal
paulmal is offline
