Alternator test data
Old Oct 27, 2002 | 11:13 PM
Mike W's Avatar
Mike W
I ran a test and thought I would pass it along to help troubleshoot charging problems. This was on a 55 amp alternator with a external solid state regulator.
RPM Bat V Field term V With head lights on Bat Field
idle 14 9.5 13.4 11.4
fast idle 14 5 14 7
cruise 14 3.5 14 5.4
This shows that at idle with the lights on, the regulator is putting the highest voltage into the field winding but still can't reach the regulator setting of 14 volts. At the high speed test with no lights, it only takes 3.5 volts to maintain the battery at 14 volts. The current thru the field winding is typically 3 amps max at 12 volts. This goes thru the slip rings to the rotor.
Old Oct 28, 2002 | 05:48 AM
77460ford's Avatar
77460ford
Post Alternator test data
Rusty_S
19
Mar 30, 2017 08:09 PM
timbersteel
Aug 19, 2016 09:51 AM
257BEE
1997 - 2003 F150
26
Apr 5, 2016 10:45 PM
ktgovols
Nov 26, 2015 10:06 AM
fast_st
Sep 5, 2006 01:11 PM
