buffer marks how to remove???
Old Jun 21, 2008 | 11:13 PM
hatchet's Avatar
hatchet
I bought a used pickup on the door of the pickup there are really bad buffer marks that show up in the sunlight and it looks really bad.is there anyway i can blend it in with polish or compound?how should i go about removing these marks from a high powerd buffer?
Old Jun 22, 2008 | 01:46 AM
ReAX's Avatar
ReAX
Firstly what kind of paint, Clear coat or just enamel? How deep are the scratches?
Rubbing compounds aren't usually intended for clear coats and might be a little too coarse. Some of the spider webbing could be in the wax, so start by stripping the wax. A clay bar or even dish soap will do a pretty good job. Then a mild polish to start, I would use mother's phase 1 pre-wax cleaner or reflections polish. If the scratches look minimal, you can try a sealer and glazer to smooth it out. If not, you will have to try a stiffer polish.
Old Jun 27, 2008 | 11:58 AM
Nyborg's Avatar
Nyborg
if its clearcoat i use 3m swirl mark remover with the black foam compound pad
