how????????
Old Jun 19, 2008 | 06:13 PM
2 stroke man's Avatar
2 stroke man
how????????
how can i make my caution lights flash as fast as they do if you have a blown bulb anytime the flashers are on? is there a way i can put a toggle on them to where they flash fast?
Old Jun 19, 2008 | 06:56 PM
kawa's Avatar
kawa
This is just my guess, but I would imagine that a lighter flasher should do the trick. Possibly a flasher for a two light system. Motorcycle comes to mind.
Rog
Old Jun 19, 2008 | 07:30 PM
mb_01sc's Avatar
mb_01sc
You could add a set of vehicle strobes behind the flasher lens on a different switch. Those would be brighter would use less battery and have less chance of overloading older factory wiring.
Not exactly what you're looking for....
Old Jun 19, 2008 | 07:52 PM
2 stroke man
i did something very stupid back in the winter. i turned down a set of strobes that were used. $35 installed. by a boy who knows his stuff.
Old Jun 19, 2008 | 08:04 PM
89ford73's Avatar
89ford73
take your 4-way flasher out. grind the cover off carefully around the lip to where u can tape it back half bass together. theres the little contact points that are about > < so far apart. you need to bend them till they are about >< apart. you can adjust the speed by how close the contacts are together. if you go way too close it will sound like a buzzer and the lights will just sort of glow. hope this helps. and at 2 bucks each if you break it, no big deal.
Old Jun 19, 2008 | 08:26 PM
2 stroke man
ok, thanks. stupid question-where exactly is the flasher on these?
Old Jun 19, 2008 | 08:43 PM
mb_01sc's Avatar
mb_01sc
My truck didn't come with a manual so I use this link often... Page 226
http://www.analogstereo.com/pdf/om/f...anual_1997.pdf
