help
Old Jun 15, 2008 | 08:44 PM
FoothillFord's Avatar
FoothillFord
help
Ive had my truck home now 4 weeks,think i have figured out the smoke(intake gasket)I could visibly see a 1/8" gap between the intake port and head surface with vavle covers off (on one port).I need to properly identify the motor to get the right gasket. when i was cleaning the block i had noticed on the front right hand side behind the power steering pump there where some numbers 87 was the top # and 352 was the bottom # I was told the motor was a 390. Are all big block stamped 352 with the pistons and crank the differances. intake #DSTE9425AIA Head #D2TEAA
Old Jun 15, 2008 | 08:49 PM
ihateminimumwage's Avatar
ihateminimumwage
Yes, the 352, 360, 390 etc. are all stamped with 352. They all use the same gasket set.
