Titration question.
Old Jun 7, 2008 | 09:44 PM
Rushmore X's Avatar
Rushmore X
Titration question.
What should good used oil titrate at? what is the ph where we should look elsewhere? I am going to start titrating oils from different places tomorrow to see what values I come up with.
Old Jun 8, 2008 | 10:22 AM
Gun-Driver's Avatar
Gun-Driver
My oil has never titrated greater than 1.7, I would say anything at 2.0 or less is good. The other thing to look for is water, take some samples home and do a water test on them.
Quantitative Water Test - Collaborative Biodiesel Tutorial
Old Jun 8, 2008 | 01:45 PM
Rushmore X's Avatar
Rushmore X
looked at the link, the next question is how much water is too much?
Old Jun 8, 2008 | 02:01 PM
fabmandelux's Avatar
fabmandelux
I've done testing in my lab with a lab scale ( weigh sample, boil off water, re-weight ) and have found that anything over 2 percent water can cause problems. Excess water will combine with the Lye in a side reaction, which lowers the amount of catalyst required for maximum conversion, resulting in lower quality biodiesel. To much water, and you wind up with "glop-soap" If you use an "open" style of processor you can see the reaction and can "tweak" it a little by the addition of extra catalyst thereby saving the batch.
kylebryan
Bio-diesel, Propane & Alternative Diesel Engine Fuels
13
May 7, 2010 02:07 PM
Rushmore X
Jan 30, 2009 02:13 PM
Gun-Driver
Aug 19, 2008 07:33 AM
Rushmore X
16
Jun 23, 2008 08:43 PM
blieux1
Aug 17, 2006 09:14 PM
