Changing wheels question
Old Jun 7, 2008 | 01:29 PM
gabocar's Avatar
gabocar
Lightbulb Changing wheels question
Hi:
I own a 1999 navi with 17" chrome oem wheels wrapped in a 255/75 17 tires.
If i´m correct these wheels have 14+ offset.
My question is
Could i change these wheels for a 01 aviator wheels with 44+ offset? and
What do tou think about the lug adaptes to convert the 5*135 lug pattern to 6 lug pattern?
Thanks
Gabo
Old Jun 8, 2008 | 05:11 PM
gabocar's Avatar
gabocar
Any advice is appricated
Thanks
Old Jun 8, 2008 | 06:36 PM
NWBronco's Avatar
NWBronco
Not really getting the offset numbers. If they equate to more out-board mounting, then I'd say no to that and the adatpers. They move things out-board as well. More stress on the ball joints, and teh steering components.
Bob
Old Jun 13, 2008 | 03:17 PM
gabocar's Avatar
gabocar
So, Do you not recommend the use of the aviator wheels in a 99 navigator?
Old Jun 13, 2008 | 08:33 PM
NWBronco's Avatar
NWBronco
Not sure. Do not understand your offset numbers. are the inches? centimeters? millimeters? Either way, a + number means outboard right? If so, you are +30 xx and then you have to add the adapter. Put the numbers together and see just how far of center you really are.
Also, will it push the tire out of the wheel well? This is illeagal n some states.
Old Jun 14, 2008 | 09:32 AM
gabocar's Avatar
gabocar
Ok, let me explain.
If i correct a +number or offset close the wheel to the fender space, not away it
The stock wheels have +14 mm offset, and the aviator wheels have +44 mm offset. The diference is 3 cm.
Therefore the aviator wheels and tires sits 3 cm inside of the fender space, obiusly using the same tires.
My question is
Need i put an adapter to return the wheel away the 3 cm for the fender space?
Thanks ans sorry for my bad english. I´m a mexican guy.
Old Jun 14, 2008 | 07:56 PM
NWBronco's Avatar
NWBronco
Your English is as good as mine. 3cm is not much differnece. So, fitting them up and seeing if you have proper clearance would be best.
cbsales
49
Dec 6, 2022 07:27 AM
flyingtexan
Jun 10, 2016 05:29 PM
Stevekron1
Nov 28, 2015 10:35 PM
White76
Oct 17, 2012 10:18 PM
4.6Liter
1997 - 2003 F150
Feb 6, 2000 12:39 PM
