Where to run amp power wire thru firewall??
Old 12-29-2002, 09:53 PM
jtp03's Avatar
jtp03
jtp03 is offline
I take delivery on a brand new 2003 F-150 SuperCrew this week and I'm already planning upgrades to the audio system. Wondering if anyone has suggestions for locations to pass amp power wires through the firewall. Are there any existing holes on either driver's or passenger side??
Lemme know.
Thanks,
J.TP
2003 F-150 SuperCrew XLT 4x4
1998 Expedition XLT (wife's)
1987 Bronco XLT 4x4
Old 12-30-2002, 03:34 AM
RanDawg's Avatar
RanDawg
RanDawg is offline
You'll probably have to drill a hole and grommet it. You may be able to find some slack between an existing hole and some wire. There may even be a plugged hole you can take advantage of. An audio shop may be able to help by drilling a hole for you.
Old 12-30-2002, 10:18 AM
John8172's Avatar
John8172
John8172 is offline
There are factory grommets you can use. The easiest one to access is on the driver's side behind the gas pedal.
Old 12-30-2002, 05:51 PM
jaxf250's Avatar
jaxf250
jaxf250 is offline
Ditto. I have used this same one in my 2001. Tight but workable.
-- Bob
2001 F250 SD CC Lariat, V-10, 4.30, 6' Bed, 4x4, Auto, K&N FIPK-2, SCMT-tuned, BFG 295/75/16 AT's
Old 12-30-2002, 10:31 PM
bumpin_BII's Avatar
bumpin_BII
bumpin_BII is offline
FooFighter73
2015 - 2020 F150
09-21-2015 02:59 PM
Mr Dave73
1997 - 2003 F150
09-19-2010 10:17 AM
wfsimons
1997 - 2003 F150
01-13-2006 03:00 PM
New To Ford
Computer Chips & Tuners
01-06-2006 09:12 AM
rob7765
Offroad & 4x4
01-03-2003 05:03 PM
Quick Reply: Where to run amp power wire thru firewall??
