Engine!?
Old May 23, 2008 | 10:13 AM
Dre82s's Avatar
Dre82s
Engine!?
So I have this tiny problem with my water pump....
I got this truck and it did not move for 2 plus years, when I got it decided to replace the water pump, all the bolts that go into the block were stripped out. there for I tapped new holes and put new bolts in place. however I keep on getting leaks on the passenger side of the block (upper radiator house) comes out of. what can I do to fix this problem permanetly?
Old May 23, 2008 | 05:56 PM
G/T's Avatar
G/T
are you talking about the upper radiator hose or the bypass hose?if your talking rad. hose make sure hose is tight or the housing isnt cracked
Old May 23, 2008 | 06:25 PM
danr1's Avatar
danr1
As said check for any cracks.
Also did you use pipe dope on the water pump bolts?
Old May 28, 2008 | 10:29 PM
Dre82s's Avatar
Dre82s
whats a pipe dope?
Old May 29, 2008 | 06:29 AM
alz's Avatar
alz
Pipe dope is like putty that is put on plumbing fittings to stop leaks from happening. You could also use teflon tape on the threads of the fitting.
flapbreaker
Aug 1, 2014 08:24 AM
jaagen
16
Oct 23, 2012 06:53 PM
NAMDROF
1983 - 2012 Ranger & B-Series
Jan 16, 2010 09:08 PM
DYDF250
Aug 15, 2007 06:20 PM
cbfomoco
Dec 16, 2005 10:12 PM
