light rust on cylinder wall
Old 10-15-2002, 09:12 PM
41Clay's Avatar
41Clay
41Clay is offline
I bought an engine that was subposivly running in the late eighties. Pulled the heads and found some recent but not bad rust, I'm guessing "flash rust." I was wondering if there was a solution that could take this out or if I could just use something like rubbing compound to remove it. I think it's in to good of shape to rebuild and want to start it up and check how it runs without scratching the cylinder walls up too much.
Old 10-16-2002, 07:55 AM
mtflat's Avatar
mtflat
mtflat is offline
Mine was in the same condition from the sounds of it. I used steel wool and penetrating oil (PBlaster, WD40, diesel, etc)and scrubbed. You might want to lay a rag on top the piston just to keep wool shards out of the rings. I got the worst of it that way and let the rings finish up.
Old 10-16-2002, 08:22 AM
mtflat's Avatar
mtflat
mtflat is offline
mailhot
10-20-2016 03:17 PM
Jerry's red Ford
19
05-09-2014 08:41 PM
compressorguy
06-24-2008 11:44 AM
trinogt
09-06-2002 08:13 AM
buzzard
07-30-2001 12:33 PM
Quick Reply: light rust on cylinder wall
