PSD Part Numbers
  #31
Old 03-27-2012, 11:24 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Exhaust manifold and up pipe nuts and bolts. The Ford number is in the big list but lacked the IH numbers.
Manifold to head bolt:
ford- F4TZ-9S425-A
internantional- 1820513C1
Up pipe bolt:
ford- W300013
international- 1821640C1
Up pipe nut:
ford- W300050
international- 40050R1
  #32
Old 03-28-2012, 12:06 PM
sbraatz's Avatar
sbraatz
sbraatz is offline
Thumbs up
Thanks to all who have taken the time to update the PSD parts list. It has proved to be a valuable source of info.
  #33
Old 04-11-2012, 11:56 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Here's another. This one an alternate to the OEM TPS:
Onlinecomponents.com
Manufacturer: Cutler Hammer
Part # SS22BW32-330Y
Hope this saves someone some cash.
Courtesy of Nomad221 in this thread:
https://www.ford-trucks.com/forums/1...l#post11694863
  #34
Old 04-23-2012, 12:05 AM
BuckHammer's Avatar
BuckHammer
BuckHammer is online now
It appears that your part numbers for Ford upper and lower idler pulleys are reversed.
  #35
Old 04-26-2012, 05:30 PM
BuckHammer's Avatar
BuckHammer
Part number F81Z-8501-CRM, which is for a Ford Water Pump for engine serial numbers 201681 and up, was superceded by part number 2C3Z8V501BA.
  #36
Old 06-09-2012, 04:21 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
E40D dipstick tube o-ring. Size -113. Number 148 in the diagram below.
  #37
Old 06-09-2012, 11:45 PM
nomad221's Avatar
nomad221
nomad221 is offline
Nate was polite in posting . The micro switch is for the IVS. No need to spend 4 bills for a complete pedal assembly anymore.
  #38
Old 06-10-2012, 06:52 AM
DIYMechanic
Well, I was going to try to edit that post to correct my misinformation, but apparently it has been too long since I posted it or something. The "edit" function isn't there! Oh well, thanks for pointing out the mistake Greg. I hate to give bad info.
  #39
Old 07-02-2012, 08:09 AM
DIYMechanic
Not really OEM part numbers, but GREAT info none the less:
Ford Truck Enthusiasts Forums - View Single Post - Vacuum Pump Info
  #40
Old 08-15-2012, 11:55 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
ford- F4TZ-9S425-A
Up pipe bolt:
ford- W300013
Up pipe nut:
ford- W300050
To complement this:
UP PIPES:Part numbers
- Driver side up pipe (Ford only) F4TZ-6K854-A comes with exhaust manifold flange
- Passenger side up pipe (Ford) F6TZ-6K854-A = (Int'l) 1824434C1
- Flange by turbo collector x2 (Ford) F4TZ-6N632-A = (Int'l) 1820746C1
- Flange by exhaust manifold x1 (Ford) F4TZ-6K854-F = (Int'l) 1820747C1
- OEM Donuts x2 (Ford) F4TZ-6K854-C = (Int'l) 1816103C1
- Bolts by exhaust manifold x4 (Ford) W300013 = (Int'l) 1821640C1
- Nuts by exhaust manifold x4 (Ford) W300050 = (Int'l) 40050R1
- Bolts by turbo collector x4 (Ford) W301160 = (Int'l) 1822895C1
- Turbo collector (Ford) F4TZ-6K854-D = (Int'l) 1818163C1
  #41
Old 02-08-2014, 10:10 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
94.5 through 97 49 state engine harness F7TZ-9A451-CA. Evidently still available per a friend that works for Ford.
creator
1999 to 2016 Super Duty
17
04-24-2023 04:01 PM
Chevy_Eater
22
07-04-2021 07:04 PM
1997F-350
222
02-01-2017 11:50 AM
1997F-350
388
12-29-2014 06:10 PM
Quick Reply: PSD Part Numbers
