speedometer calculation
Old Apr 30, 2008 | 11:22 PM
imlowr2's Avatar
imlowr2
Since I've changed my wheels and tires and gear ratio in the rearend. My speeedometer seems to read 10 mph too slow. I have a C4 transmission and I know it's easy to change the driven gear to calibrate your speedometer. Has anyone done this? What is the rule of thumb as far as number of teeth to make the speedometer read correctly. I know with the 3.5 gears, it read pretty close to accurate? With the 2.75 gearing, I'm about 10 mph too slow. Any help is appreciated. In other words my speedo reads 50 but I'm doing 60 mph.
Old Apr 30, 2008 | 11:48 PM
Bob at warsaw's Avatar
Bob at warsaw
I didnt know that you could change that.
Are you saying you can do it with diffrent
gears?
Old Apr 30, 2008 | 11:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I used to have the part numbers for C4 speedo gears; I think there are only 3 or 4 choices. They are color-coded. It seems to me that the more teeth, the faster the speedo would read for a given speed. NumberDummy will probably be able to set you up!
Old Apr 30, 2008 | 11:54 PM
imlowr2's Avatar
imlowr2
Bob, if you pull out your speedo cable from the transmission, you'll notice a gear on the end. It's held with a C clip. Remove the clip and replace the gear with one with either more teeth or fewer teeth. That will adjust and calibrate your speedometer. It just a matter of which gear with how many teeth you need to put on????? You can buy the gears on epay, they run about $10 each plus shipping.
Old May 1, 2008 | 12:04 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Believe it or not, they were in stock when I went to my local Ford dealer and (ten years ago) were $6 apiece or so. They are apparently common to many different trannies (the one in my F-1 looks the same).
Old May 1, 2008 | 12:38 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Somewhere online there is a chart. I was doing research about 6 month ago and found it (actually there are several)
My speedo is about 15mph fast (its on my todo list.....I'm waiting until I change diff gears)
I'll bet a search for C4 speedo gears should turn up some sources
Bobby
Old May 1, 2008 | 12:54 AM
Kurt G.'s Avatar
Kurt G.
I had a 79 Trans Am that needed the gears changed. I went to GM dealer told them my axle ratio and the gears I had, Tailshaft and cable.They ordered the correct one. I'm sure Ford can do anything GM can do, only better. Don't forget about transducers ( I think they are called). They go between speedo cable and trans to fine tune speedo. The TA had one. Kurt G. Y-blocks rule.
Old May 1, 2008 | 01:03 AM
Sandidande's Avatar
Sandidande
"But Officer, I couldn't possibly have been speeding I changed the speedometer gear myself."
I have done it and it's easy. It's as described above And, I have taken vehicles to speedo shops and had them fine tune it with those little inline gear box thingys Kurt is calling transducers. Works great. You could probably take it to a speedo shop and get the gear changed and if need be the transducer to fine tune, get it tested and a calibration card for less than $40 or so.
Also, if you have a tach in your vehicle and know the wheel role out (exact circumference), You can use the gear/transmission calculator on the site to tell you exactly how much the speedo should be off at any given RPM.
Old May 1, 2008 | 08:53 AM
ALBUQ F-1's Avatar
ALBUQ F-1
So Imlowr, if you are reading 50 when you're going 60, you need a gear with 60/50 = 1.2X as many teeth as you have now. If you have a 24 tooth, you need a 28 or 29 (closest). If you are too far off, you'll need a converter piece like Dan said, or have to the speedo recalibrated..
Old May 1, 2008 | 11:41 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I've been through this a few times. Generally, one tooth is worth about 5 MPH. If the speedometer is too slow by 10 MPH you need a gear wth two less teeth than what you have now to speed it up. If no such gear exists then you would have to get your speedometer recalibrated or go with some kind of converter. My truck is running a 2.26 rear gear with a TH350 transmission and there isn't a gear with fewer teeth available so I'm running about 6 MPH slow using a gear with the fewest teeth available.
Old May 1, 2008 | 01:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Are you sure it's less teeth for more MPH? I used to remember it because it seemed opposite of what I would think, but anymore it all sounds backwards...
Old May 1, 2008 | 06:55 PM
jaye's Avatar
jaye
I just did this change a couple years go I went from a 2:75 to 3:55
. If I'm not mistaken I was running 16 teeth with the 2:75 rear end. I google speedometer gear calculator and found a calculator try this one Speedometer Gear Computation. I went to a local Ford dealer and brought two different sets for about $6 each. There is another web site that had the colors to match the different teeth
Old May 1, 2008 | 08:39 PM
CIAF's Avatar
CIAF
Ed, check out page 1 on the link. These guys are so awesome IMO. There will be no guess work, or measure. They can calc for you on gears,tire circ,speed. I just follow a pal in a car that is accurate at 60 MPH for a mile then call these guys and 3-4 days later I have my stuff. It is real simple. I think I used Part # 82 on 1 of my C-4 trannies. It is listed half way down the page. I think it's a pretty cool site overall and I hope it helps you out. Jon
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Old May 1, 2008 | 11:34 PM
Bob at warsaw
Wow Jon, thats a great web site, wish they made gears for
a 57 wiper motor
Take care
Old May 2, 2008 | 08:24 AM
GreatNorthWoods
More teeth on the driven gear slows down the speedometer and less teeth speeds it up. I went from 15 teeth to 11 on my truck to get it as close as possible...
