2002 Ecursion trans. problems
Old Apr 27, 2008 | 09:59 PM
insulation man's Avatar
insulation man
Just wondering how many miles other people are getting out of there trans. I have 198000 on this thing and today it acted like it was slipping at low rpm going up hill. on flat no problem or if i powered up alittle bit no problem. does this sound like a replacement or something else. Also i have never changed plugs or coil packs, u joints. I guess i need to do this.
2002 excursion limited
2004 38' Travel trailer
Old Apr 27, 2008 | 10:51 PM
afreemanmd's Avatar
afreemanmd
Check your fluid. If its burnt you may have issues with the trans, if its not, the problem is likely elsewhere.
I had a trans start slipping like crazy a few years ago on my X, and it ended up being an ECM issue, but it was slipping so bad that the truck was not driveable, so I don't think thats your issue. Id check the fluid at the dipstick and just go from there.
good luck!
