Louisiana Chapter Join Chapter, Leader: rbloodhound
1990 F-250 7.3l
Old 05-06-2008, 02:42 PM
kidkuzz's Avatar
kidkuzz
kidkuzz is offline
1990 F-250 7.3l
Hi all I have a few questions. I just bought a 1990 F-250 7.3L and i just wanted to find out any problems that any one has had in the past with this engine and what modifications i could do to this truck to improve the look and power.
Thanks
Curtis
Old 05-06-2008, 08:09 PM
rbloodhound's Avatar
rbloodhound
rbloodhound is offline
There is a lot that can be done to increase the performance. The fuel can be turned up on it for one. You could add an aftermarket turbo. Check out the idm forum. They will have a lot moe info than I do.
Old 05-07-2008, 06:14 AM
kidkuzz's Avatar
kidkuzz
kidkuzz is offline
thanks for the info.
Old 05-07-2008, 06:35 AM
rbloodhound
No problem.
Old 05-07-2008, 07:29 PM
cajunland's Avatar
cajunland
cajunland is offline
I know the cps (crankshaft positioning sensor) is notorious for going bad. Ford just did a recall on them. Also the uvch (under valvecover harness) can go out (but not as common). I also gutted the gate valve (stuck open) on my '97 f350. The diesel forums on this site are very helpful for me, as was dieselstop.com.
Hope that helps.
Old 05-08-2008, 06:27 AM
kidkuzz's Avatar
kidkuzz
kidkuzz is offline
Thanks all that has been changed in the past year from what i was reading in the maintenance log that the guy kept on everthing that he did. Thanks for all the tips and help that you have giving me.
Thanks
Curtis
