syntec oil or not
syntec oil or not
hey guy's I hear lot's of storys about syntec oils I would like to know what you think of this . I am at the moment debating if ishould go for it .When I bought the 05 xlt the dealer put sintec in it but after i went back to regular because of the price. Now I came across these guys AMSOIL 0-20w full syntec could last 25k miles.
I would not run a synthetic oil that far without doing an oil analysis to determine how long exactly you can go between changes. A lot will be determined by the driving you do. Is it all highway or in town or a combination. The analysis should be the determining factor on oil change intervals. All that said, my experience has been that synthetic oils don't generally last that long between changes. I'm not saying they can't, just don't generally.
Ehh, because you bought a $40,000 truck! If you don't want to spend money to keep it up, you shouldn't have bought the truck.
Besides, it's NOT extra money when you factor in extended drain intervals, and less wear on your truck. It's a no brainer and proven over and over gain in independant lab tests. With modern ignition and fuel injection there's hardly any oil contanimation like there used to be with older inefficient engines.
Keep in mind Amsoil states "Up to 25,000 miles" and also states in severe conditions is 15,000 miles.....OR one year which ever come first. Everyone in North America falls into the severe catagory.....so even if you extend your drain interval from 3,000 miles with dino oil to 5,000 miles with Amsoil, you're ahead.
The $50 a year I spend on a synthetic change is worth the extra $20....for in 10 years that extra $200 won't rebuild my engine or tranny.
I'm not saying anything bad about synthetic oils. I think they are good. But before I ran any extended oil change intervals with any kind of oil I would have an oil analysis done. You can have one done at 3000 miles, 6000 miles, and so on until the analysis tells you it's time to change oil. I run Motorcraft synthetic blend in my truck and the wife's Taurus. The oil gets changed at anywhere from 2000 mile intervals to 5000 mile intervals depending on conditions. In the winter we change oil a little more frequently because of a lot of idling. When I tow with the truck I'll change oil at 2000-3000 miles. Otherwise, 5000 mile intervals are good and probably a little more frequent than necessary. On my old 94 beater Taurus I run Castrol GTX and change oil at 3000 to 4000 intervals. 165,000 miles on the old girl and the engine is still good. It still goes along at the speed limit without any oil consumption and gets 24-28 mpg. I wish the body was as good as the drivetrain. Just get the analysis before pushing the intervals too far out so you don't have major engine problems. That way you know for certain you are safe.
Find me one engine that failed after 150,000 miles because of lack of lubrication! There are many FTE members with well over 200,000 miles on hard worked modular V8s that have never seen synthetic oil!
I hear both of you and you both have good arguments .what's picking my curiossity on this is a buddy of mine is running this Amsoil now for many years in his dodge ram diesel close to 300km replaces the oil once a year and no troubles . I also read the explanation from amsoil why they can go so long without oil changes compared to other brands they say there oil is not syntetised from petrolium base product . It is completly made from engeneered lubricants (from the lab )
The idea of running extended intervals is one area I will not argue against! It's a proven fact that modern synthetics can last a VERY long time in an engine.
Switching to synthetics for this reason makes sense. Switching to synthetics and still changing every 5,000 miles based on the myth that your engine will last longer with synthetic oil is a waste.
The benefit is longer oil change intervals, not necessarily better protection.
If I go with regular oil I have to replace it once a month at 40$ cost 500 a year and if I use this amsoil at 80$ a year if it last that long or even change it twise a year I am still a head and a lot less waste for the enviroment .Everibody here seems to agree that syntetic oils are better.
yeah believe it or not 50/50 highway /city I wounder what does an oil analasis cost and how much work is involved for me .
another thing I read in most cases to go from oil to syntetic oil manufaturer sugest an oil flush but i also read night mare stories on the results but they wher mostly high milage engine . Some syntec oil companies state that there syn oil has a detergent that also helps in the cleaning of sludge and other deposits.
another thing I read in most cases to go from oil to syntetic oil manufaturer sugest an oil flush but i also read night mare stories on the results but they wher mostly high milage engine.
