Code 45
Old Apr 17, 2008 | 06:48 PM
jemini's Avatar
jemini
Code 45
After much help on this forum over the past year I have got my 1988 F250 351 to the point where it runs quite well. Frustrating as this truck was to fix , it was really satisfying to finally bring it back to good health -sort to speak. As some of you might remember, I had a run in with Rhino Engines about them not giving back my $150 core refund on the reman. I bought from them. The long/short of it was that after several months in correspondence with the Better Business Bureau in New York, Rhino finally refunded the money. I only had to wait 9 months! Pain in the *** company if there ever was one.
I ran a check today and got a code 45 (thermactor upstream during self test) with the engine running. KOEO was fine, an 11.
Would a code 45 point to one of the 2 black solenoids (TAD or TAB) as having gone bad? What is the best way to test this problem out?
Thanks
Old Apr 17, 2008 | 08:57 PM
Conanski's Avatar
Conanski
The code is telling you one of the diverter valves is not in the right position for the test, could be a bad solenoid but could also be a stuck valve or a broken vacuum line between the solenoid and valve.
Old Apr 17, 2008 | 09:50 PM
jemini's Avatar
jemini
Thanks, i'll check the lines and the valves.
