Trouble codes
Old Apr 14, 2008 | 07:03 PM
King0581's Avatar
King0581
Trouble codes
Install my wicked wheel today and went for a test drive with my programer in stock and had no problems. Put the programer on level 2 (Race) and went for a drive(Pretty fast to check it out) and the check engine light came on. Pulled 4 codes from the edge. A p0475, po478, p1282, p1211. Cut the truck off and went for another run without any problems.Then put it back to stock and tried to pull up codes and it says it has none stored. What do those mean?
Old Apr 14, 2008 | 07:13 PM
mkmathis76's Avatar
mkmathis76
see link in the message
mkmathis76's Avatar
mkmathis76
Welcome to guzzle's Diagnostic Trouble Code list Web Page here they all are...
F350-6's Avatar
F350-6
P0475 Exhaust Pressure Control Valve Malfunction
P0478 Exhaust Pressure Control Valve High Input
P1211 ICP Not Controllable — Pressure Above/Below Desired
P1282 Excessive ICP
Sounds kind of like a result of the WW & tuner. You can check to make sure your EBP tube isn't clogged, but the 0478 can also be tied to an overboost condition. I'm hoping you have a set of gauges to monitor things. Have you considered a larger exhaust?
Edit: Now that's just sad. mkmathis76 can post twice before I can spit out one response. Way to go with the quick fingers.
Old Apr 14, 2008 | 07:28 PM
King0581's Avatar
King0581
I'm pretty sure its not clogged. Had it at the dealer a while back and I'm pretty sure they had cleaned it out. I have the gauges on the edge and I never saw boost above 18. Was looking more at the road while I was test driving. I installed the wicked wheel for when I get the bigger exhaust. Thinks thats my main problem? Hopefully the wife will buy the exhaust for my b-day!
Old Apr 14, 2008 | 08:06 PM
F350-6's Avatar
F350-6
Well the 1211 is a common ICP issue with a chip. The 2 things that jump out at me from the 0478 are overboost and restricted exhaust.
More air in has to = more air out right? I hope your birthday is soon. Maybe someone else will chime in with their experiences on this.
Old Apr 14, 2008 | 08:27 PM
King0581's Avatar
King0581
Yep! Its in a couple weeks. Until then I'll keep it in the stock or no more than tow setting. Also keep my big foot out of it! Thanks. Might just junk the muffler this weekend for safety!
Old Apr 14, 2008 | 08:42 PM
F350-6's Avatar
F350-6
Those have been know to fall off from time to time.
Old Apr 14, 2008 | 08:53 PM
King0581's Avatar
King0581
I know I should check the line going to the wastegate to make sure its ok,also!
Old Apr 14, 2008 | 08:59 PM
F350-6's Avatar
F350-6
Sorry, I guess I should have shared more.
KB1 DIAGNOSTIC TROUBLE CODE (DTC) P0475 (EPR)
possible causes:
shorted to power
open/grounded circuit
damaged solenoid
damaged PCM
Disconnect EPR harness connector.
DE17 CONTINUOUS DIAGNOSTIC TROUBLE CODE P0478
DTC P0478 indicates an excessive back pressure condition existed during normal driving.
Possible causes:
stuck EBP butterfly valve
restricted exhaust
plugged EBP sensor line
misadjusted EPR linkage
F-Series wastegate turbo may be overboosting
Old Apr 15, 2008 | 05:23 AM
King0581's Avatar
King0581
I know the P0478 is because of the exhaust, butnot real sure what caused the Po475
Old Apr 15, 2008 | 05:26 AM
King0581's Avatar
King0581
I think theP0475 could be because my EBPV is now my exhaust brake!
Old Apr 16, 2008 | 06:13 PM
King0581's Avatar
King0581
Would that cause the P0475 code?
Old Apr 16, 2008 | 07:34 PM
F350-6's Avatar
F350-6
I'm guessing you're correct on this. Maybe someone who has done this can confirm it.
Old Apr 17, 2008 | 04:03 PM
King0581's Avatar
King0581
Did some trial and error testing today and the P0475 and P0478 are coming from my exhaust brake. I made sure all codes were clear and flipped it on and then pulled the codes again and they were there. Would a overboost annihilator be something I should look into buying?
