What have you done to your truck today?
  #18031
Old 04-13-2015, 10:40 AM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
Got the oil pump primed and oil pump driveshaft installed yesterday on my 88 F150.
Also cleaned my 88 F150 and the 90 F150. Also rinsed off the 89 F250. Didn't feel like completely washing the 89 F250 since it is a work truck. That is about all I have had time to do lately.
Trav
  #18032
Old 04-13-2015, 11:01 AM
85F350IDI's Avatar
85F350IDI
85F350IDI is offline
Originally Posted by Zoidberg
I didn't do this today but better late then never. DIY front bumper repair/paint with front plate mount deleted. I'm happy with the results and I need to do the back bumper and grill I think. Any tips on grill and headlight bezel painting?
You have my trucks brother haha I've been wantin t paint the grille and bumper black like yours
Sorry crappy quality lol
  #18033
Old 04-14-2015, 09:08 AM
Redneckfordf2502002
Yesterday installed lower intake manifold, stabbed the dizzy, and got her pretty much ready to be dropped in today. Just have to install the rear main seal and freeze plug in the back of the engine. Also exhaust manifolds and motor mounts.
Also pressure washed engine bay and picked up 6ft of vacuum hose.
Won't have her running right away but will hopefully have her in and somewhat bolted down today till I can get more work done on her Saturday or sunday.
This is on my 88 F150.
Once this is running and driving good I will park the explorer and start driving her! Can't wait to be back in a full size!
Trav
  #18034
Old 04-15-2015, 05:48 AM
Zoidberg's Avatar
Zoidberg
Zoidberg is offline
Well what are you waiting for?! Lol. I enjoy seeing my trucks brothers out there still running.
It was a little bit of work since I removed the bumper and the plastic air dam(?) before painting. Unfortunately you have to drill the rivets and I used some nice stainless screws to reattach.
Total cost was under $40ish and I still have all the bondo I can eat.
  #18035
Old 04-15-2015, 09:06 AM
85F350IDI's Avatar
85F350IDI
I'm waiting for extra money to get ahold of paint, wondering what kind of grit I oughtta use for that bumper, I figure I might as well do the back bumper too, wonder what it'd look like if color matched? Also is the air dam riveted on?
  #18036
Old 04-15-2015, 09:17 AM
ng19delta's Avatar
ng19delta
ng19delta is offline
Well, yesterday I tried to do a quick check of the CCC solenoid, which is the 94 code the truck is throwing. As it started raining on me, I rolled under the truck, and disconnected the plug into the transmission... Of course, I managed to break the retainer on the plug... I found the clip on the shift position switch was also broken... So I ordered two repair kits on e-bay... Great... For now, I'll use a mechanic's trick with zip ties to keep them secure. And I discovered the transmission heat shield was missing... Anyone have a photo of one?
Scott
  #18037
Old 04-15-2015, 11:13 AM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
well this was two days ago, but I was working on the mustang touching up the paint on it (still have more to go) and took some of the clear coat touch up stuff and touched up a few spots on the truck, so that should at least help a bit with rust protection and prevention (i hope), now I just need to go out side and inspect and see if it worked at it started raining about 30 minutes later but it was a 70* day with very low humidity so I hope that helped some...
  #18038
Old 04-15-2015, 03:30 PM
Redneckfordf2502002
Didn't get the chance to get the engine in yesterday for a couple reasons but transmission pan on the 90 F150 started leaking slightly again.
Trav
  #18039
Old 04-15-2015, 04:22 PM
90Ford73's Avatar
90Ford73
90Ford73 is offline
Today I did some touch-up painting on the cab of my '90 F250 7.3 idi Supercab Longbox. ZF5 surrounded by an XLT Lariat cab. Great reliable truck.
I am new to this forum and I think this thread is cool!
  #18040
Old 04-15-2015, 04:38 PM
taz11's Avatar
taz11
taz11 is offline
Today....well, NOTHING
But on Monday I successfully removed the cab on my 96 cc. No casualties except a mildly twisted clutch hydraulic line....got snagged when I wasn't looking.
It took me until today to recover enough to post about it. I'm getting to old for this madness
  #18041
Old 04-17-2015, 09:43 PM
ng19delta's Avatar
ng19delta
A little bit of kismet today... I actually drove her in to work today: I used a round a quarter tank going around 30 miles... So I think I need to figure why: I am planning to change the transmission fluid tomorrow, and I want to give her a compression check as well as new plugs... I hope to be able to afford a new cap, rotor & plugs shortly...
Anyway, I got a call this afternoon, asking if I still had the running boards I'd listed on Craigslist: I'd removed them from my 91 XLT lariat SC/LB, and had no use for them. I was asking $150/bo... Anyway, I replied I did, and he asked if I'd take $100 for them... Well, $100 in hand is better than a pair of running boards in the yard, so I said "SURE!" Worked out a meeting point, and in about half an hour I had $100 in my pocket, and he had my running boards in the custom built bed of his F-350 diesel dually...
Anyway- that $100 went into 4 gallons of Mercon, a couple bottles of Type F & some Bars Leak Power Steering Conditioner... I was going to get plugs, too, but found a couple other things I couldn't live without, so I have to wait on them. So now I know what tomorrow will bring- another day under the F-150 on ramps, new tranny juice, and a drained & refilled power steering system! I will also be doing the connector swap on the trans harness, hopefully between the new juice & the new connector, the MIL trip will go away for good... I am hoping to get a compression check in, if I can pick up new plugs- no point wasting motion replacing antiquated sparkers... And I'll probably set up the XM radio & roof marker lamps
So- anyone got any suggestions how to fix the mileage?
Scott
  #18042
Old 04-17-2015, 10:32 PM
Chrisrehpot's Avatar
Chrisrehpot
Chrisrehpot is offline
Originally Posted by Fastback460
Nice paint job, i'm usually not a fan of flat colors but that looks good
And it makes the wheels look really glossy...lol
Oh, and what happened to the rear bumper?
A very big rock! Sorry for late reply.
  #18043
Old 04-18-2015, 12:53 PM
big-ugly's Avatar
big-ugly
big-ugly is offline
Scott
Start with a basic tuneup, like you're planning. Include a fuel filter, and check for leaks anywhere in your fuel lines, and check fuel pressure at the rail. If you're feeling ambitious, you could also clean your throttle body.
  #18044
Old 04-18-2015, 07:58 PM
Krisverde's Avatar
Krisverde
Krisverde is offline
  #18045
Old 04-18-2015, 08:05 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
Originally Posted by Krisverde
Exhaust was finished up on my 89 today.
That sounds really good! Got any pics of the parts on the truck?
Quick Reply: What have you done to your truck today?
