Aerostar Ford Aerostar
4L Powertrain Problem
Old Apr 10, 2008 | 03:42 AM
96_4wdr's Avatar
96_4wdr
since last fall on vacation, the Aero 4L has been having an intermittent jerk stumble problem on hills, freeway on ramps under medium load in 3rd 4th and LU. had noticed a 10>20% drop in fuel mileage. ran fine on freeway cruise, steady speed, around town. problem not always present
no codes. nothing on scanner.
thought it was a transmission problem either lockup clutch or OD band slip/grabbing. band or clutch bad or valve body problems.
researched it all winter thru bad weather. part of 4L OBDII EEC-V PCM algorithm is to drop out of TC LU or drop a gear down when a power/miss problem is detected. will upshift and/or go into LU when problem clears
apparently cycles quickly
resolution:
did the easy shot in the dark repair first. replace the spark plug wires. old ones only had 30k on Motorcraft. must have damaged one wire while replacing lower intake manifold gaskets last fall.
runs perfect now, full power, no shift jerking, gas mileage back up.
researched. AC Delco now has the manuf. contract on Motorcraft plug wires at plant in Mexico. replaced with AC Delco 8MM full silicone, exact lookalike for MC and less money
bonus; solved the ignition noise problem since new in radio on AM band with 3 sets of plug wires
Old Apr 10, 2008 | 07:45 PM
99f350sd's Avatar
99f350sd
Good fix! Those silly wires will get us every time...
Dick
Old Apr 10, 2008 | 09:32 PM
marty600's Avatar
marty600
Thanks for the tip..were the delco wires 'direct fit', IE, from a chart?
Or, were they a "universal" application /hi-performance set ?
Old Apr 11, 2008 | 03:07 AM
96_4wdr's Avatar
96_4wdr
direct fit, exact same as the Motorcraft made by AC Delco
Expedish98
Oct 31, 2012 01:44 PM
KhanTyranitar
Aerostar
Feb 4, 2011 04:03 PM
Vacationtime247
Jan 14, 2011 04:09 PM
Ryan50hrl
General Automotive Discussion
15
Jul 28, 2008 08:57 AM
Rally218
Sep 23, 2003 05:09 AM
