Ground for Computer
Old Apr 7, 2008 | 03:11 PM
qman's Avatar
qman
Ground for Computer
Where is the Computer (ECM?) in my 92 F150 and where does it ground?
Old Apr 7, 2008 | 03:34 PM
quicklook2's Avatar
quicklook2
look below the brake booster a little to the outside, that is the ecu, or computer.
the ground is the to bolts holding it in.
one bolt holds the wiring harness in, remove that and you will see the other two bolts.
buy a manual if you do not already own one.
Old Apr 8, 2008 | 10:49 AM
qman's Avatar
qman
I have a Ford shop manual. It's pretty worthless when it comes to electrical.
Old Apr 8, 2008 | 11:42 AM
Conanski's Avatar
Conanski
The computer is grounded via the harness.. and there are actually several grounds. On pre '91 trucks it's accessed from the drivers side kick panel in the cab, on later models you have to pull it out from the engine compartment. I just spend all day Sunday trying to make mine fit with the Tweecer module attached.. it took quite a bit of cutting and welding.
Old Apr 8, 2008 | 11:52 AM
quicklook2's Avatar
quicklook2
you need the ford service electrical manual for specific electrical help.
my service manuals from ford covers most of the electrical info that i need.
