First Automatic
Old Mar 25, 2008 | 08:36 PM
seafire's Avatar
seafire
First Automatic
Hi all, I just got everything back together from doing a cab, bed, and front clip swap. I need some help with my automatic transmission. It shifts from park to reverse and neutral. However, I'm having problems with it when you put into drive. You can take off, but it will not shift through the gears. It seems to be stuck in first or second. I don't know what to do next.
Thanks for the help
Old Mar 25, 2008 | 10:30 PM
vanwho's Avatar
vanwho
Did you put the vacumn line back onto the transmission modulator valve? If not, put it back on and try it again.
