Intake
Old Mar 25, 2008 | 11:47 AM
Ford150/428/dud's Avatar
Ford150/428/dud
Intake
I recently purchased a non egr performer intake for my 351M, along with 3 key timing set. Im going to trim the gaskets of from the valley pan and use mr.gasket intake gaskets for the intake to head.
If my intake gaskets come with plugs to block off the egr at the head, will it benifit me to add a 1inch carb spacer to keep the carb cool?
thanks
NIck
Old Mar 26, 2008 | 08:44 PM
bubbas78f250's Avatar
bubbas78f250
I am running a holley 670 truck avenger ontop of a weiand. I have not had an isue yet.
Bubba
Old Mar 26, 2008 | 08:49 PM
danlee's Avatar
danlee
The carb spacer does more than to keep the carb cool. It helps to reduce the turbulance at the carb. I would use it unless you have some clearance problem.
Old Mar 26, 2008 | 09:30 PM
Ford150/428/dud
Ok that sounds good.
I know that most of the carb spacers I see dont have any vaccume ports??
Thanks
Nick
Old Mar 26, 2008 | 09:46 PM
bubbas78f250
what ddo you need more ports for???
Bubba
Old Mar 27, 2008 | 10:15 PM
Ford150/428/dud
Ok the reason I dont know for sure is because my truck is locked in a shed for winter storage. The owners of the shed "relatives" are on vacation and took the garage keys with them. It sounds pretty stupid but hey its free storage!!!
So as I understand my factory 2bbl carb has a vaccume port either on the carbs base or under the spacer. The aftermarket spacers from what I have seen dont have any vaccume ports on them, and the carb I want to use doesnt have a vaccume port on the base at all.
Do I not have use those vaccume ports or am I just thinking too hard??
