Sponsored by: Kumho
4wabs problems
Old Mar 23, 2008 | 08:21 PM
mnhaught's Avatar
mnhaught
4wabs problems
I have a 97 Expedition. About a month ago the ABS light came on. I purchased a Actron ABS scanner to retrieve the codes. The code was C1155. So I cleaned the connector and light went out. Today, I was driving around and truck went crazy when I hit the brakes. The ABS light returned. So I pulled the codes again. This time I got C1155, C1230, and C1158. I did some test's on the RF sensor to see if I could match the measurements that got on the left side. Now the RF sensor has joined the club. The resistance measures 480 Ohms on the two front sensors. I can read AC voltage when I spin the tires. I checked the plugs at the sensors and the hydraulic system, but I did not find any corrosion. I don't know where to look now.
Any help would be appreciated
Marshall
