Hello,
i have a 2001 excursion V-10 about 2 weeks ago it was very cold and i started the truck locked in the 4 wheel. It went into 4 wheel not problem but the light on the dash read incorrectly 4high not 4low. it went in and out of 4 wheel and since that happened i have no brake lights or turnsignals. the center brake light above the door does work but nothing else. anyone have any ideas? i need the truck for the family easter weekend get away and can't seem to find the problem thanks for your help
yes all fuses under the dash and under the hood are good.last night all lights were working except the lowrange light on the dash and the right front turn signal.i checked the bulb and the fuse,the bulb was blown replaced it still doesn't work and i am not getting any voltage to the socket. I am however getting voltage through the fuse. any other thoughts besides the harness?
