Modular V10 (6.8l)
E85 Converted V10
Old Mar 18, 2008 | 08:19 AM
mizzitch's Avatar
mizzitch
E85 Converted V10
My 99 F-250 now runs on either gasoline or E85. I had a flip switch programmed for both tunes. So far the E85 is doing better than expected for MPG. I am getting 9.8 w/ E85 verses the 10.5 that I should be getting with gas. (lots of short trips and city driving)
6.6% drop in mpg
19.7% drop in cost per gallon (87oct 3.09 & E85 $2.48)
The real comparision will come with a few longer distance trips...
Old Mar 18, 2008 | 11:09 AM
MarkMoore's Avatar
MarkMoore
Waht all do you have to do? I've been told you not only have to reprogram the PCM, but you also have to replace the fuel lines and injectors. With the continual riase of gas, it maybe a worth while investment.
Old Mar 18, 2008 | 11:30 AM
mizzitch's Avatar
mizzitch
One of the shops I looked at had an 01 Crown Vic that had run on E85 for 40,000+ miles. There are many people that believe that the non-flex fuel vehicles have fuel systems that can handle E85.
I just had a program written and put on the diablo flip switch. Runs great, only difference I noticed is at start up it idles higher to begin with, but the computer may just need to get used to the new tune. There has been no noticeable change in power.
Old Mar 18, 2008 | 11:41 AM
MisterCMK's Avatar
MisterCMK
The fuel lines, tank and injectors should all be fine with E85 as far as the material goes. Depending on the duty cycle of the injectors they might need to be upgraded. Other than that, the tune takes care of the rest.
mizzitch, did you have them adjust the shift points and such with the tune or is it just simply converting to E85?
Old Mar 18, 2008 | 11:45 AM
mizzitch's Avatar
mizzitch
They used the shift points etc from my 87octane dyno tune.
I'm not sure if they lowered the rev limiter to compensate for the injectors, I know one shop was saying that they may have to lower it.
Old Mar 18, 2008 | 12:49 PM
bigrey6306's Avatar
bigrey6306
I would love to run the E85 on my V10
Did it in my wife's Ranger and liked it alot
Theres even an E85 station right accross from my work
Old Mar 19, 2008 | 11:46 AM
MarkMoore's Avatar
MarkMoore
mizzith,
Who did the programming? Cost?
I'm interested in this for both the Excursion and our Accord, but it has to be cost effective with a relative short ROI. Right now there are very few stations that sell e85 in my area, but it's $.25 cheaper than gas.
I've been searching around and found 'conversion kits' ranging from $300 to $500... which is robbery.
Old Mar 19, 2008 | 11:50 AM
mizzitch's Avatar
mizzitch
$200 plus my used Diablo Preditor
www.rune85.com
Andy was pretty good for a guy that just had his wisdom teeth removed...
Old Mar 19, 2008 | 01:51 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
VERY interesting thread
Old Mar 19, 2008 | 02:07 PM
MisterCMK's Avatar
MisterCMK
I concur
Old Mar 19, 2008 | 04:24 PM
MarkMoore's Avatar
MarkMoore
www.rune85.com
Similar cost... I guess if I already had the diablo, it would be worth it - but with the small price difference and loss in MPGs it just doesn't add up for now (at least for me). But it's something to keep in mind.
Old Mar 19, 2008 | 04:28 PM
mizzitch's Avatar
mizzitch
it depends where you live in the country - E85 prices vary quite a bit - since it can't be distributed by pipeline
Old Mar 19, 2008 | 09:15 PM
SLE's Avatar
SLE
Right now in ND its $0.80 cheaper than Regular depending on the station.
Old Mar 19, 2008 | 09:47 PM
MisterCMK's Avatar
MisterCMK
Yup, that sounds about right SLE. Where in ND are you at?
Old Mar 20, 2008 | 06:53 AM
MarkMoore's Avatar
MarkMoore
Here in Charlotte, NC - there are only a few E85 stations. Price is only about $0.25-$.030 lower than gas.
