Cleaning of Fuel Injectors.....
Well I'm hoping to have the van out soon and would like to get the fuel injectors cleaned professionally with a pressurized system. Just wondering if anyone else has noticed a difference after having it done...???
I have a `87 EB with the 3.0L but I'm pretty sure these same injectors are quite common in other setups too.....
~Justin
~Justin
Originally Posted by Pablo-UA
Yes, immediatly, but if you will cleane them on engine some cleaning mixtures may kill spark plugs.
~Justin
First - engine runs more smoothly, MPG - a bit better, power - better, starting in the cold - no difference....
Seriously, under the for-what's-worth category, I pulled my injectors with more than 260,000 miles on them and they looked perfectly fine. I put five of them back in (after replacing head gaskets) and a new one - due to some klutz dropping the old one and it landing right on the injector "nose". I mostly run Shell gasoline with the injector cleaner additives. Whether this helps - who knows?
