Removing front u joint question
If you are referring to the axle joint, then no. The tire, lockout, caliper, rotor, and hub have to be removed and then the whole axle will slide right out for you. Difficult? No. Time consuming? You betcha. A little patience will go a long way for you on this one. Sorry for the bad news.
cfdrives3 is correct, you have to take it all apart.
That axle is held in with three bolts holding on a retaining plate. I had a hard time getting mine out, so I somehow wrapped one end of a chain around it with the other end wrapped around the, um, I call it a knuckle, the spindle attaches to it (and the wheel & tire go on top of that). I then turned the steering wheel which turned the knuckle thinger which pulled the axle out for me. ;-)
-ct
-ct
