Depending on the style of roller rocker, having a roller in the area of the fulcrum help wear and tear, compared to sliding. And a roller on the tip of the valve helps to pevent less guide wear, less sliding there too.
Been talking to Crower, they now here a roller bearing in the tip of the roller rockers (an option you purchase). Most rollers on the tip is just a roller on a pin.
They have found that under high RPM and big spring pressures the friction of rolling on the pin raised the temp of the valve spring. Their new roller in the tip lets the spring run cooler.
What you should pay close attention too is the rocker to valve stem geometry since you are changing things. That's the area between the tip of the vavle and the rocker tip. Some times a different length push rod is needed with or without roller rockers.
