speedometer problem
Old Jan 31, 2008 | 12:59 PM
davidcam's Avatar
davidcam
speedometer problem
What are the most likely probnlems witha speedometer that just quit working? I have a 94 F150 and all the other gauges work fine, the speedometer just stopped working today. Thanks in advance for any help.
Old Jan 31, 2008 | 02:09 PM
superduty4x4's Avatar
superduty4x4
VSS in the rear end- it's the only sensor back there, 2 wires, bolted right to the top of the differential. If not that, open the rear diff and check the tone ring- it's what sends the signal to the VSS. Next culprit is wiring between the VSS and the PSOM (behind the speedo). Last thing to check is the PSOM. If its your PSOM, you'll want to junkyard a used cluster, just be aware that your truck will show whatever mileage the donor rig had because the PSOM stores mileage info.
Old Jan 31, 2008 | 03:50 PM
davidcam's Avatar
davidcam
Thanks for the info
Old Mar 15, 2008 | 09:46 PM
dehamma's Avatar
dehamma
I too have no speedometer. It jumps when I deccelerate. I have changed the VSS (ABS sensor) in the top of the rear differential. What is the PSOM? I am thinking the tone ring since the speedo works while decceleration?
Old Mar 16, 2008 | 08:13 AM
fmr9's Avatar
fmr9
dehamma
Your 89 has a mechanical speedometer, it is much different than the 94 that was being discussed.
You need to pull the speedometer cable at the tranny. I would slide the innner cable out of the sheath to see if it is well greased, or possibly broken. If it is ok, grease it well and reinsert it. Then chuck the end up in a drill and spin it while someone else watches the speedometer. If the needle still doesn't turn, the gauge is bad. If it works fine, the gear driving the cable in the tranny is bad.
Good Luck Frank
Old Mar 21, 2008 | 08:47 PM
gbrewer's Avatar
gbrewer
I've got an 87 f-150, speedometer was making a light ticking noise. Was running fine until all of a sudden would not shift into 3rd gear. Did transmission filter change, Still no 3rd gear. Replaced speed sensor where cable goes into transmission. Now runs great with no ticking. I think the ticking sound was the sensor going bad.
