Sponsored by: Auxito
Leaf Spring prob
Old Jan 28, 2008 | 03:54 PM
almost_nick's Avatar
almost_nick
Leaf Spring prob
I went off roading and when i got back i see that the spacers that are inbetween the leaf springs are comming out and both bottom springs are off centered... what can i do to fix this
Old Jan 28, 2008 | 05:17 PM
ididntdoit99's Avatar
ididntdoit99
You should be able to jack the frame up as high as you can, and that should relieve enough tension on the springs to pound them back into place. A small prybar should spread them apart far enough to stick the spacers back in there.
Old Jan 28, 2008 | 05:27 PM
jdcpjc's Avatar
jdcpjc
2000 Ford Explorer
I hear a clunk every once in awhile underneath the front side of my Explorer. It just started happening yesterday. It doesn't happen all the time...occasionally when I hit a bump in the road but sometimes not at all. It sounds like its coming from underneath the drivers side floor board but I haven't gotten under to look yet....any ideas for me???
Old Jan 29, 2008 | 12:30 AM
superdutymj's Avatar
superdutymj
Probably a balljoint, but they'll be able to tell you in the Explorer forum
Old Jan 29, 2008 | 08:01 AM
Spotty's Avatar
Spotty
I know on the older Explorers the passenger side radius arm bushing sat right next to the catlytic converter and eventually destroyed it. This will really clunk around in the hole once it is destroyed. It's not a real tough fix, I think the whole rebuild kit is under 40 bucks. Good Luck...
Spotty
