electical help
Old Jan 25, 2008 | 02:16 PM
ford&excavators's Avatar
ford&excavators
electical help
I was rewiring up my hydrogen system the other night and I messed up. I plugged the power wire from my battery into the acc plug on the switch. And the ground wire into the power plug on the switch. And so of course when I hooked the battery back up it all melted in a cloud of smoke. The good news is that it didn't really seem to hurt anything at first. Truck started fine. But then it started raining today. Ya. The wipers don't work. I have no idea how it happend. Makes no sense. Anyone know where the fuse for the wipers are?
Old Jan 25, 2008 | 02:53 PM
PaysonPSD's Avatar
PaysonPSD
In my 99 it is underdash fuse 11, 10amp.
Old Jan 25, 2008 | 04:46 PM
AustinS's Avatar
AustinS
On my '01 it is #11 (30A) also under the dash. Then check the battery junction box under the hood for # 2 mini (10A) and the bottom three relays.
Austin
Old Jan 25, 2008 | 05:50 PM
ford&excavators
Thanks! that was it.
Old Jan 25, 2008 | 07:02 PM
F350-6's Avatar
F350-6
That doesn't sound like the best way to start your hydrogen generator project. Hope things get better. Make sure you post back somewhere with results of how it works. Also make sure you have an inline fuse in your generator set up.
