rust fix
Old Jan 24, 2008 | 01:43 PM
fordboy67's Avatar
fordboy67
rust fix
I live in Minnesota where they salt the roads like crazy. My 98 expy is showing rust only on the pinch welds on the bottom of all 4 doors. Is there any way to stop the rust before it gets to the point of no return? I love this truck and can't afford to replace it with a newer one. Any advice will be appreciated, thanks.
Old Jan 24, 2008 | 01:47 PM
SBastow's Avatar
SBastow
try painting it with POR 13. I have a 99 EX and the driver/passenger doors doing the same. I live in Pa and face the same problem with salt
Old Jan 24, 2008 | 01:57 PM
fordboy67's Avatar
fordboy67
Did the POR 13 work? Does it spray on, brush on? Do you need to sand down to bare metal or go over the rust and is it supposed to stop it if you go over it, Thanks.
Old Jan 24, 2008 | 02:04 PM
SBastow's Avatar
SBastow
sand the rough spots and brush it on over the rust. not sure if its a long term fix or not. its worth a try though.
Old Jan 24, 2008 | 02:06 PM
fordboy67's Avatar
fordboy67
Thanks for the reply, I'll give it a try! Like you said it can't hurt to try!
Old Jan 24, 2008 | 09:33 PM
bruce381's Avatar
bruce381
I used "rust Bullet" wire brush, clean and brush on a few coats read instructions my truck was from Michigan and had rust in seams lifting paint. I used rust bullet about 2 years ago and NO rust has come back after a few days I did spray paint bottom of doors with factory match paint and looks very nice.
bruce
Old Jan 25, 2008 | 06:58 AM
fordboy67's Avatar
fordboy67
Bruce, thanks for the info maybe I'll try POR 15 on one side and Rust Bullet on the other and see which one works better, Thanks again.
Old Jan 25, 2008 | 05:22 PM
bruce381's Avatar
bruce381
rust bullet has I think on the web site some comparisons to others I liked that rust bullet in that you didi not have to get out all the rust in fact they want some left to make it react and dry.
bruce
Old Jan 25, 2008 | 10:35 PM
AGE's Avatar
AGE
Rust is bad bad news for neat vehicles. I drove a lot of neat cars in PA for 40 years. For the first 20 years I lost many to rust. Then I found the solution. Get a garden sprayer and spray oil all over the underside and frame and inside the doors (especially door edge seams) and quarter panels every Oct-Nov when the vehicle is dry. Rub the fender lips with wheel bearing grease. Sloppy yes but it works and extends sheet metal life. I had a 78 Bronco for 18 years and a 68 Cutlass for about 15 years with zero rust. I'm sold for this approach in the rust belt. I now live in FL--no more rust.
Old Jan 26, 2008 | 08:10 PM
Jimmygunz3's Avatar
Jimmygunz3
I have a 99 eb expo with the same problem. I think I am going to try rust bullet and see what happens. Where is a good place to buy it from. Thanks
Old Jan 27, 2008 | 09:51 AM
c_hohensee's Avatar
c_hohensee
I am also going to try Rust Bullet. I ordered some straight from their website using a link from an ad on this site.
lynran
2015 - 2020 F150
Apr 9, 2017 06:26 PM
MDSuperDuty
Oct 24, 2015 09:25 AM
4x4ford33
Jan 6, 2015 09:35 AM
SuperDuty93
Jun 27, 2012 12:10 PM
nucleartruck
Jun 14, 2005 03:58 PM
