Hey guys, Its been really cold the last couple of days and when i went to start my truck the other day it just "tried to start". After trying for a couple of times I pumped the gas pedal and it did turn over and run. However when i took my foot off the gas pedal it immidiatly died. It did this twice! The third time i left my foot on the gas and revved it for about 20 seconds and then i could feel the computer kick in and give it enough gas to idle. Just wondering if this is common with the v-10. Since it is fuel injected Ive always heard you dont pump the pedal but thats the only way this one will start. And only when its below zero outside and not plugged in! Any tips or solutions would be great, thanks in advance
Kurt, where is the idle air bypass mounted on the engine?
I have a 1999 if that makes any difference.
How do you clean it? Do you take it out or just spray carb cleaner in it?
Thanks,
George
George, I looked in my chilton and it looks like its the Idle Air Control Valve (IAC) and it appears to be on the back of the throttle body with a couple of bolts holding it on and a hose coming out of it. And i would guess you would just clean it with carb and choke cleaner? Anybody with any experience please chime in!!
Sounds like they have you pointed in the right direction with the IAC. So...just to help out...here is a link to my gallery with step-by-step instructions on removal and install with pics. https://www.ford-trucks.com/user_gal...&albumid=22274
