Wife's F-250 Stereo Build.
Old 01-22-2008, 12:20 PM
bgalaxy67's Avatar
bgalaxy67
bgalaxy67 is offline
Originally Posted by johnperdeye
huh ill have to try it and see never thought about raising the frequency up that high
Now again, it depends on the driver. If it's an 8" sub, it might not like it that high. If it's a midbass driver then it should fill in nicely.
Old 01-23-2008, 12:06 AM
johnperdeye's Avatar
johnperdeye
johnperdeye is offline
i see ur doing a blow through in the bed
Old 01-23-2008, 12:17 AM
bgalaxy67's Avatar
bgalaxy67
Yes sir!
I'm planning to cut this weekend. I just hope the weather is a little better then it has been for the first part of the install.
Old 01-23-2008, 12:20 AM
bgalaxy67's Avatar
bgalaxy67
Alright. It's about 99% done. I'm one resistor away from being complete.
Here's the last of what I will call Phase one
I made a temp bracket for the kill switches. I haven't decided where I want them yet.
Then we have the Bass ****
Finished up the power to the battery.
They work
Quick slide of the deck.
Put the seats in over the Nav
And the Sirius.
Home sweet Home
Old 01-25-2008, 04:05 PM
bgalaxy67's Avatar
bgalaxy67
I gots me some wire in today
Team Broke-*** Style
It's a little bigger then the 1/0 I had laying around
Good thing it's flexible.
And since I don't want it to burn to the ground I picked up some circuit breakers
Almost a pound a foot.
Old 01-26-2008, 08:18 PM
bgalaxy67's Avatar
bgalaxy67
Started the 2nd part of the build today
Old 01-26-2008, 08:19 PM
bgalaxy67's Avatar
bgalaxy67
Old 01-26-2008, 08:47 PM
Skoda's Avatar
Skoda
Skoda is offline
Hey man your making some serious progress with the build though the pic with the cutting tools and lines of where you were going to cut made me sit here for a minute and jut say to myself(NO he didn't). Say the well engineered box, was just wondering how, what your going to use to fill the viods between the cab and the bed that the box goes into?
Best of luck
Old 01-26-2008, 08:51 PM
bgalaxy67's Avatar
bgalaxy67
Best of luck
Thanks!
It took a little sweet talking to the wife to get this one going.
I'm going to use an Accordion Boot Seal around the edges then in between the boot and port I will use expanding foam
http://www.crlaurence.com/ProductPag...8.html?Origin=
The Port will cover the boot so it looks nice and clean.
Old 01-27-2008, 11:09 AM
johnperdeye
ahhh a blow through got love them....also what wire is that it looks like welding cable
Old 01-27-2008, 12:38 PM
bgalaxy67's Avatar
bgalaxy67
4/0 flexi-shield Welding cable. I've been disappointed in the car audio stuff for awhile now. It's either aluminum tinned copper or the jacket is super thick to make the wire look like it's the right size.
Here it is next to 4G wire.
Old 01-27-2008, 01:59 PM
johnperdeye
i can get u some great wire from my sponsor if u want and i promise u want be disapointed
  #28
Old 01-27-2008, 04:12 PM
bgalaxy67's Avatar
bgalaxy67
PM me some Sizes, Specs, and Prices.
  #29
Old 01-27-2008, 06:47 PM
bgalaxy67's Avatar
bgalaxy67
Not much to see today, Mostly tying up some loose ends. The Accordion boot won't be in until Tuesday so I had to cover up the hole.
I put in all the brackets to hold the boot cover in place. It will be screwed together when the boot comes in.
Then I started on the doors for the last time. It's a little cold out so It's a slow go process.
I'm out of resin so I'll be making another trip to the store tomorrow.
Tonight I'm working on the box design so I can get the wood tomorrow.
I also spent a few hours tunning the processor. It was a little easier this time because I had my notes from the X
  #30
Old 01-27-2008, 09:24 PM
johnperdeye
il have to call and get specs u can check out the wire at dblink.net its strandflex wire
Quick Reply: Wife's F-250 Stereo Build.
