Leaking Coolant
Old 01-19-2008, 07:23 PM
LRanger97's Avatar
LRanger97
LRanger97 is offline
Leaking Coolant
Hello all, I replaced my heater plenum about a year ago. I figure while I was in there I would replace the heater core and the heater control valve under the hood by the firewall. Ever since the valve has leaked. I only notice it when its really cold.I had taken the new one back for a replacement and it does the same thing. Not alot of coolant being lost at one time but it trickles out of the valve. Anyone else run into this? I hope evryone is well, Joe
Old 01-19-2008, 08:18 PM
pintopower8's Avatar
pintopower8
pintopower8 is offline
could be a bad part supplier? Take it back, get a refund, and Try a different store.
Old 01-19-2008, 08:26 PM
msully005's Avatar
msully005
msully005 is offline
did you change the hoses too? i changed one of the hoses to my heater core and the inside dia. was just a little too big so i had coolant leaking inside of the cab of my truck.
Old 01-19-2008, 08:31 PM
LRanger97's Avatar
LRanger97
The hoses seemed to be in ok condition, so I didn't change them. Luckly it leaks outside the truck. Thanks for the input.
Old 01-20-2008, 07:19 AM
cmoore's Avatar
cmoore
cmoore is offline
The hoses can appear to be O.K. and still leak just a little. I just replaced a heater hose that appeared to be O.K. but had a very small leak in it. They just get old and brittle.
Old 01-20-2008, 02:59 PM
LRanger97's Avatar
LRanger97
Gotcha, I'll change the hoses and go from there, Thanks again for the input!
