Throttle Assembly Replacement
Old Jan 11, 2008 | 01:28 PM
matttaubert's Avatar
matttaubert
I just received my replacement throttle assembly from Powersroke Shop. I am going to make the replacement on Sunday and wondered if anyone has done this before and if so does the cable on the top of the assembly that I assume controls the postion of the throttle just pull off or is there an other method to remove it? It appears that it will just pull out.
Thanks
Old Jan 11, 2008 | 01:54 PM
zx250's Avatar
zx250
Of the next Riffraff East
It's all just plug and play. No cables, just wire and wire plugs.
Old Jan 11, 2008 | 04:26 PM
h2guy's Avatar
h2guy
AFTER you release the little lock on the side of the plug.
