Powder-coated stock wheels...
Originally Posted by boxcar1974
which stock wheels are you going to powder coat. The key is awesome prep. If they are polished aluminum it is not a do it yourself job. You will never get coating to stick. That was what I ran into when I clear powder coated my SVT wheels. Most guys who powder coated did not even want to touch them. I finally found one guy who knew how to do it.
Originally Posted by cdrmotorsports
boxcar brings up a very good point. I totally forgot about the preperation. If you have steel wheels you should be OK, but you'll run into trouble with most other finishes.
Yep, lots of places say you can't powdercoat polished aluminum or chrome.
If the guy is good......he can do both.
I would highly polish things just for my guy to powder since we were using a translucent color.
He would also send parts to get chromed....just so he could do a translucent color on them. Looks good since the color really pops in the sunlight.
Right.........my polished aluminum SVT wheels I was gonna scuff them up myself to put a clear powder coat to them........just to see if I learn something.
Scuff the polish.........try removing the polish.
Originally Posted by F350-6
Now how come I never thought of that? All these years of watching commercials about how well this one or that one breaks down grease.
Boy my wife is gonna be pissed.
Not to discourage the guy from powdercoating on his own, but unless he plans to powder coat lots of other stuff in the future, it may be more trouble (and cost) than it's worth to DIY, rather than to take them down to the local powder coat shop.
Here's what you're gonna need:
- Powder coat gun (Harbor Freight for about $50, Eastwood for about $100, I've used both and they work fine)
- Oven to bake the items in. For small items, I use a little toaster oven from Walmart for about $30. For the bigger items, I picked up a used range for about $50. Of course, for the full-size oven, you'll need 220V wherever you plan to use it.
- Not needed 100% but highly recommended: A media blast cabinet. Metal has to CLEAN before you coat it. And while you could sit there for hours or days with wire wheels, grinders, sandpaper, etc, a media blast cabinet can make life so much easier.
Finally, you'll want to practice before you do your actual item. There's a lot of little "gotchas" that you only learn from experience.
But if you really want to get into it, then you can turn out some great looking items for a fraction of what it will cost you to pay a local shop.
For items larger than will fit in the big oven range (pretty much a tire rim is the max item for that), I've been wanting to build a bigger oven. It's not too difficult to build an oven that will accomodate much larger items. However, here's a trick for all you "old home oven" users: I built a box out of insulated wall board that has one side open. The open side is the same dimensions as the opening to the oven. I just open the oven, leave the door down, and place the insulated box on the door, covering the opening. I can pretty much double my baking area like that. It takes a little longer to get the whole area up to 400 degrees, but it's a much simpler solution than getting or building a bigger oven.
TX
TX
Originally Posted by fivonut
If you're referring to me... I'm already knee deep in it. I've been playing with my setup for a year now. I have intentions of doing a lot more powder coating than one or two items and have a small CNC company interested in having me do some small part work for them.
TX
#28
#29
#30
Hey fivonut, since you're already set up to bake, check out GunKote by KG Coatings. Somewhat similar process, and useful for some things that powder coat isn't. Cheap to get into as well, since all you'll need is a cheap airbrush to spray it on.
Have fun!
TX
Have fun!
TX
Robert6401
12-05-2011 03:07 PM
bigredtruck
05-14-2007 10:09 PM
