The other day i was walking out from the store where i get my mowers serviced. I left the headlights and foglights on because i new i wasnt going to be in their long. After all my business was done in the store, i hoped in the truck and tried to start it. For a about a minute, the start motor was cranking but the engine wasnt turning over. After i tried that i stopped trying to crank the engine. Then i turned the key again to try and get it started again. Now the starter motor wouldnt even crank. It just made a clicking noise. It did that for about thrity seconds. While it was making the clicking noise, the needles on the gas guage and batt guage where both going up and down. I stopped trying to crank it then and gave it little rest. About 1 min later i tryed to crank it again and the this time, the starter motor was cranking but the engine still wasnt turning over. I did this for about 30 seconds and then i pushed my foot on the accelerater and all the sudden she started up. She has driven fine with out a problem since (this was a week and a half ago). The truck has done this about 3 times and does it every 3 or 4 months. What do u guys think?
How old is your battery? I think Autozone will do a load test for you. If your battery is fairly new, get them to test your alternator too.
Assuming you have good batteries/wiring, this sounds like what used to be called the Bendix gear in the starter. This is the gear that is forced forward to engage the perimeter of the flywheel, etc. to turn the motor over.
At this point though I'd just get the battery and alternator tested.
I replaced the battery 3 weeks ago from autozne for previous problems. My motorcraft problem was fried. But the duralst gold which had 1000 cranking amps fixed the problem.
Unfortunately, electrical power issues can be a chicken-and-egg situation. Yes, your battery failed and you replaced it. And many times the problem is just that. However, sometimes the REASON the battery failed is because the alternator isn't putting out power sufficient to keep the battery charged, say, because it fried a diode.
Consequently, if you develop more electrical problems, say, a month after replacing a battery, you need to get your alternator load tested, because even a new battery will fail if you can't keep it charged.
Thanks, the battery i bought is alot bigger then the OEM batt that died on me
My truck had a similar problem but a little worse than yours and a new starter solved it
but dont forget to check all your grounds while you're looking
my problem was that it would just click when I turned the key for about twenty times, then it would crank slowly and then start
all the while the chimes and windshield wipers would be going on and off intermittantly
It happened today again. But the guages werent going up and down. It was just a clicking noise everytime u turn the key. After about a minute of turning the key, the starter motor started to crank and the motor just started. What the hell?
sounds like you could have a bad main ground try clearing it and see if that doesn't fix it. what will cause your gauges to go form 0 to max and then back is when it reset form losing all power. Also try cleaning the starting solenoid connections might fix it.
