Need Help With Engine
Old 01-30-2008, 02:31 PM
MONTANAANDRES's Avatar
MONTANAANDRES
MONTANAANDRES is offline
Thumbs up Need Help With Engine
HELLO GUYS HOW CAN I KNOW WHAT ENGINE DO I HAVE IN MY ECONOLINE WHRERE ARE THE NUMBERS AT ? ALL I KNOW IS THAT IN THE DOOR TAG IT SAYS ITS A 1965 BUT THE DOORS ARE ORANGE AND THE TRUCK IS WHITE MAYBE THE LAST OWNER CHANGE THE DOORS PLEASE HELP
Old 01-30-2008, 03:38 PM
cobraguy's Avatar
cobraguy
cobraguy is offline
If it is a stock 65 econoline it would have a 200 or a 240 the 200 will have an integral intake manifold(part of the head can't remove) the 240 will have a removable intake. Welcome to FTE and please turn off your CAPS LOCK its like your yelling. Rich
Old 01-30-2008, 03:48 PM
jschira's Avatar
jschira
jschira is offline
The valve cover on the 240 is also bigger and more square.
Just in case, the 200 has 5 freeze plugs on the intake side of the block. The 144 and the 170 only have 3.
Old 01-30-2008, 07:13 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by jschira
The 200 has 5 freeze plugs on the intake side of the block. The 144 and the 170 only have 3.
144/170/200/250 I-6's: The intake manifold is part of the head, it is not removable.
240/300 I-6's: The intake manifold is removable.
Vehicles after 1948 are registered by the VIN number.
The VIN engine code is the 4th digit (thru 1980).
1965: J = 240 / S = 200 / T = 170
Old 01-31-2008, 07:03 AM
jschira's Avatar
jschira
jschira is offline
The VIN is on the door tag and the doors on these trucks got swapped out routinely. Unless you know for a fact that your truck has the original doors, the door tag is the last place to look.
