In-tank fuel pump mod completed
#92
#93
#94
I bought my parts from all sorts of places in a slow buildup to the actual modding of the tank. The fuel filter and fuel pump sat on my workbench connected to each other for a month before they got installed. I also did a lot of the preparatory work like the pump electrical supply relay beforehand.
#95
[QUOTE=99SevenPoint3]
When I got my fuel pump from napa I wanted the one in the pic above. I got a walbro gsl 392 in a carter box. I thought it was a mistake but after checking with everyother napa and carquest I found out that they had switched, why im not sure. But you might run into the same problem. The good side is that the walbro is a much better pump imo, and you will find dodge guys running them as an upgrade to there stocker. I cant seem to find the stats on the walbro, but if I do ill post.
#96
I'm about to wear out the internet looking at doing an in-tank pump. I just did the ITP in tank kit w/ Baldwin filter and wish I did the big bad Bosch instead.
Has anyone looked into using the in-tank pump with the Baldwin filter on the positive pressure side? I worry about throwing +/- 70 PSI at it.
FYI- I did both SS HPX tube and the ITP tank kit at the same time. No question, the motor idles smoother and quieter now. However, I can hear what appears to be air in the (#8?) injector worse than ever. At 2,000 RPM under light load it is driving me crazy. The simple cure is to mash down a little on the throttle and let all he!! break loose, but that does not always go over too well around here.
Damn, I hate PMS
Damn, I hate PMS
#99
#101
#102
Originally Posted by Kwikkordead
Basically the procedure is remove the check valve from the outlet end of the pump and drill it out. Then weld a small piece of pipe to the end of the check valve that you can weld to the pickup tube.
#103
#104
#105
