1978 - 1996 Big Bronco
transfer case replacement
Old Dec 29, 2007 | 07:22 PM
jccastl's Avatar
jccastl
I have a 88 bronco with the manual 1356 borgwarner transfer case behind a ZF manual transmission.
I need to replace the transfer case.
Could I use any manual 1356 t-case?
Would a manual 1356 bw that was behind a C6 auto transmission work.
I just need to make sure the new t-case will bolt up to both tranny and rear driveshaft side!!
Any help would be appreciated.
thanks jcc
Old Dec 31, 2007 | 08:30 AM
Kemicalburns's Avatar
Kemicalburns
yes i would think it should work
Old Jan 1, 2008 | 05:54 PM
rlh's Avatar
rlh
any 13-56 from a Ford will work.
Old Jan 4, 2008 | 11:02 AM
justshootme84's Avatar
justshootme84
While the BW 13-56 t-cases all have the same bolt pattern for the transmission adapter, there are a few different styles of output yokes or flanges. Also, the F-150 yokes are different size than the Bronco yokes - what a PITA when swapping t-cases.
Old Jan 4, 2008 | 01:48 PM
alxsnmr's Avatar
alxsnmr
You should find a BW1356 case from a bronco or find another case and swap in the appropriate output pieces from your current case to the replacement. You state you have a ZF tranny so is this already a franken truck?
cwells1106
Oct 7, 2016 11:09 AM
landon460
Oct 2, 2009 08:57 AM
tmcgin
Feb 17, 2006 10:33 AM
rebelford
Nov 20, 2005 07:10 AM
BlueOvalDrifter88
Nov 17, 2005 12:14 AM
