S. California Chapter Join Chapter, Leader:
Greetings So-Cal!
Old 12-14-2007, 09:34 AM
forenglishpressone's Avatar
forenglishpressone
forenglishpressone is offline
Greetings So-Cal!
Hello everyone.
I am here trying to keep my expy alive for a few more miles. Seems like I hit 100k and a switch went off...now I'm on a 1st name basis with the AAA man. Thanks in advance for all your help.
Cheers.
-J
Old 12-14-2007, 09:57 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Welcome! The "King of the SUV's" forum will get you squared away. Lots of knowledgable folks that are happy to help out.
Old 12-14-2007, 11:22 AM
Kep4's Avatar
Kep4
Kep4 is offline
Jäger
Welcome to FTE!
You may want to go into 'User CP' and add your location and add information about your Expedition ( engine, trans, 2wd/4wd, prior problems, etc...). That will help us help you. (Think Jerry Maguire... )
Old 12-14-2007, 01:50 PM
73f350sc's Avatar
73f350sc
73f350sc is offline
Welcome,
If you could describe exactly what its doing, that would be helpful in an attempt to help you figure out what the issue is... =)
-Chris
Old 12-14-2007, 09:48 PM
forenglishpressone
2001 Expedition 4.6
The truck doesn't like the wet weather @ all. Hard or no start when we get rain, which isn't that often so I have ignored it in the past but recently it has been more of an issue. Recently the truck stranded my wife but managed to start again and limp home. Then a couple days ago it came home on the hook. I looked through the forums here found some common issues and knocked them out today. I needed a new battery and that led to new terminal connections. Totally worth the :45 minutes to clean everything up and install the new ends. So now I had full cranking power but no fuel pump noise so I dropped the tank and swapped out the pump and filter. The truck started right up so hopefully I killed the problem. All in all I am in maybe 4 hours of time and 297$ and everything seems to be working fine.
Now I just have to wait and see if the problem comes back. Hopefully it won't and I'll forget allllllll about it
Does anyone know if the moisture/rain issue is in any way tied to the fuel issues I just addressed? I read something about the GEM module getting wet?
wpnaes
07-15-2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
05-20-2011 10:40 AM
nflfreak43
Tennessee Chapter
101
02-10-2010 12:47 PM
HiSPL
Testing.....
08-19-2009 05:52 PM
Ford_Six
11-13-2002 08:45 PM
Quick Reply: Greetings So-Cal!
