2009 F-150 At New Ford Quality Control Center
#33
Originally Posted by ford390gashog
What happened to the frame? The current F-150 does not have all those "swiss cheese" holes drilled in the frame. Can someome say welcome back to the 80's. Second the current F-150 has tube cross sections welded through the frame rails I did not see any in the pics. The tranny is the 6 speed used in the expeditions right now.Looks like just a body change for 09.
#34
#35
if you look closely the lower control arms are not aluminum like the current model. the cab is a little longer and the front finders are larger. that is that is the only difference I can see in these pics. I don't want to over analyze what I see though. these pictures are of test mules, not the final product. until this thing goes into production there will probably be a lot of little changes made.
#36
Originally Posted by Skeeter94
that is an 09 you can tell by the 3rd brake light and the fenders. That is an Extended Cab not a Crew Cab and it appears to be a tad bit longer than the current Extended Cabs. just my .02 take it or leave it
#37
#40
#44
I hope Ford tightens up their quality control. I am actually on the market shopping for a new truck to replace my 98 F150(of course, I am going to buy another Ford). I don't mind what engines Ford is going to use in its new F150 or what price the new truck is going to be, all I care is the new F150 is the best quality truck in the market.
98 Ford F150 XLT 4X4 4.6 196000K
#45
Originally Posted by horsepuller
Looking good. Does anybody know what "trim skillet" is?
The trim skillet has an electric lift that sets the job to the desired height at each work station. It's a "smart" skillet that communicates to the operator about the job that's on it, if that operator has to choose among commodities to install. The chassis line has dumb skillets as well, without the electronics.
If you're in Detroit, you can tour the plant and see the skillets in action. The tour is run through the Henry Ford Museum.
builtfordtough13
Ford vs The Competition
17
12-09-2008 01:37 PM
builtfordtough13
03-19-2008 10:17 AM
builtfordtough13
2009 - 2014 F150
57
01-22-2008 12:02 PM
builtfordtough13
243
01-20-2008 05:19 PM
builtfordtough13
2009 - 2014 F150
15
12-06-2007 02:57 PM
