Veg oil and Gasoline Mix?!?!?!
Came across a post in a biodiesel forum talking about what this guy is doing. What do you all think of this...is this the "secret" to "Diesel Secret?"
http://www.oilcrusher.5u.com/
Yes, the RUG thins out the oil and also produces a chemical change to the oil so that it does not 'string' when pushed through the injectors. This will help avoid coking of the injectors and rings. It's also a good idea to add a cetane booster to the mix to help smooth out the combustion process.
Gas has been a winter additive to diesel for decades. It helps to thin it out and prevent clouding in the cold.
I normally run about 20% #2, 75% WVO, and 5% Reg Unleaded. My truck still doesn't have the power it has with straight #2, but a lot more than it did with straight WVO. I do know that an old volkswagon diesel a friend of mine has recommends up to 20% gas mixed with the diesel in the winter, so obviously you can go up pretty high with it. I am considering switching from gas to just putting propane injection on my truck, but I'm not sure about it.
Originally Posted by Phydeaux88
Do you have any proof that gas "produces a chemical change in the oil (sic Veg Oil)". I do not believe that is possible.
Ford's Secret Zoodad: Putting a hole in the header panel for the snorkel to breathe - without water!
Y2KW57
22
08-26-2020 10:35 AM
Tim Hodgson
35
10-12-2015 11:20 AM
