What CFM for a built 351w
Old 11-04-2007, 08:23 PM
JCastellaw's Avatar
JCastellaw
JCastellaw is offline
I have a 351w freshly built with a 268 cam, bores .30 over and an edlebrock preformer intake in a 74 ford bronco automatic. I stay on the Hwy. most of the time but am not afraid of the mud. I need a new carb. the 4180 I have which came on the engine almost killed me the other day when it hung open!!!
What carb do I need and what CFM? I also want and electric choke.
thanks!
Old 11-04-2007, 10:39 PM
Putt's Avatar
Putt
Putt is offline
Formula says a 600 cfm would be fine, I would recommend vacuum secondaries. I like Holleys, but an Edelbrock Performer carb would work well. Holley List 80457 with the Ford AT linkage would work.
Old 11-04-2007, 10:41 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
A 600 or 650 would work fine. You can go with a Holley truck avenger or an Edelbrock 600.
Old 11-05-2007, 09:32 AM
JCastellaw's Avatar
JCastellaw
what about a 670 truck avenger????
Old 11-05-2007, 09:37 AM
JCastellaw's Avatar
JCastellaw
ALSO, IS THE TRUCK AVENGER WORTH THE EXTRA 150 OVER THE 600 Holley List 80457 ?
Old 11-05-2007, 10:32 AM
jonbass40's Avatar
jonbass40
jonbass40 is offline
I would run a 600 Edelbrock if you don't do serious off roading and if you do than i would go with the truck avenger 670, although you will need to tune it down a little to get mileage out of it. The truck avenger costs more because it is designed to work at a steeper angle without flooding the engine. If you run mostly flat to moderate hills than you will never see the benefit of the avenger and you will just be wasting money. The regular Holly will also work well, it just is personal preference as to which one you want. The eldelbrock is a little more beginner friendly, but with a little practice either one is easy to tune.
Old 11-05-2007, 05:31 PM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
The 670cfm would be way too big!
Over-carbureting an engine is the most common mistake most people make when building up their engines. When you over-carburete an engine, it will hurt your gas mileage, pollute the air more, and it won't reach its potential until you get into higher rpms.
351 X 5,000 RPM / 3456 = 507cfm
...and that calculation is based on 100% volumetric efficiency. Stock engines typically run at 70-75% volumetric efficiency. "Race" engines typically run at 90% VE.
In other words, YES, you COULD use the 650cfm, but it will be harder to tune, it won't idle as well as a smaller carb, and it won't run right at lower RPMs because that a 650cfm is good for 6400RPM. BE REALISTIC. Are you going to RACE your truck? Will your truck REALLY run up to 6400RPMs? When you over-carburete, you are only hurting the end result.
For street use, 600cfm at the most. The Holley 570cfm Street Avenger would be a great choice.
Old 11-06-2007, 08:31 AM
JCastellaw's Avatar
JCastellaw
Is 600 too much? I found a refurb on Ebay for 179.00!
Old 11-06-2007, 01:06 PM
jonbass40's Avatar
jonbass40
Run the 600 it will work good with just a little tuning and it will give you room to upgrade in the future.
Old 11-07-2007, 02:08 PM
JCastellaw's Avatar
JCastellaw
I bought a 600 holley form national carburators in fla. it cost me 175.00 plus 20.00 shipping. Better than the zone which was 259.00 plus tax. what upgrades latter??
Old 11-07-2007, 02:15 PM
JCastellaw's Avatar
JCastellaw
Also what should she idle at cold and warm???? what rpm should it kick down???
Old 11-08-2007, 07:30 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Warm, about 650 in gear, cold about 1100 to 1200 for a few minutes until you bump the throttle.
Old 11-09-2007, 10:44 AM
JCastellaw's Avatar
JCastellaw
Thanks guys! You have been great help!
Old 11-13-2007, 07:04 AM
96sherm's Avatar
96sherm
96sherm is offline
awesome thread, i had the same questions myself!!!
Old 11-18-2007, 04:34 PM
JCastellaw's Avatar
JCastellaw
Guys just a little update. i put a holley 600 on it and she runs perfect. will turn over my p buckshots. I bouthg a space but to make it fit, i will hove to drill the threaded holes out and the space is aluminum. where can I get a good spacer that will work on a edlebrock performer intake and a holley 600??
Quick Reply: What CFM for a built 351w
