Missouri Chapter Join Chapter , Leader:77&79F250
Tachometer
Old Oct 31, 2007 | 07:25 AM
javlin360's Avatar
javlin360
Tachometer
Help please, my son has a 98 ford ranger with a 2.5 (if I remember correctly) it has dual spark plugs per cylinder, single overhead cam. This truck did not come with a factory tachometer and from what I have found, I do not see where there is a hook up terminal for a tachometer. My son is wanting to install an aftermarket tachometer that is capable of working with this year model truck. We tried to hook it up at the most logical place I could think of, the tan wire from the coil, but I only get about half of the input signal. In laymans terms, if the engine is at 2,000 rpm, the tach might read 700-1,000 rpm. Where do I interface to get an accurate rpm reading? Any help will be greatly appreciated, thank you. I can be e-mailed directly at dpmmsa15@hotmail.com.
Old Oct 31, 2007 | 09:49 AM
tcbofade's Avatar
tcbofade
Hi there. And welcome to FTE .
I'm not much help on the smaller Rangers, (I have a great big one!) but you might have better luck here --> https://www.ford-trucks.com/forums/forum35/
Good luck!
