4.9L-6 Oil Pan Gasket
I've got a leaking oil pan gasket on my '94 F-150 4.9L-6. Looks like the gasket "squished" out somewhat during engine assembly at the factory. The area is right above the oil filter. It's not the filter, because the engine is high and dry above the rail. Time has gotten the better of the gasket, and now I've got a persistant leak.
How much of a job is it to change this thing out with the engine still in the truck? I don't mind lifting it off the mounts, but I really hate thinking about pulling the engine just to change this gasket. Looks like the gasket set up is two side rail pieces with front and rear "half-moon" pieces to go over the mains. I really only need to replace the left side rail piece; the other side is dry.
Has anyone pulled this off with the engine still in? How much of a nightmare was it? Give me your thoughts...
Thanks
Thanks
I had to do mine about 6 or so months ago. Not a problem. The gaskets on your truck is a one piece rubber gasket. You can just drain the oil and unbolt the pan and rest it on the crossmember. There is not alot of room but enough to do the job. Because the gasket is rubber it does not stick to badly. Once you have the pan down just cut the old gasket and pull it out of the way. You have to work the new gasket in around the oil pump and be careful not to bend the pickup tube. Set the gaket in place and put a little bit of silicone on the corners of the dips in the pan. You dont need to use silicone any other part of the gasket. The gasket i got had 4 little plastic holders that held the gasket to the bottom of the motor and the pan slid over them to hold everything in place as you start all the bolts. Then just tighten the bolts up and fill her back up. If you have any more question I'll do my best to help.
Jacoby
1994 f-150 4x4
Inline 6
6" lift
35" BFG Mudders.
Jacoby
1994 f-150 4x4
Inline 6
6" lift
35" BFG Mudders.
Well, I used the stock four piece gasket on my rebuilt 4.9 and even though it took a couple of goes, I found that if I used a tacky enough gasket sealer and let it FULLY set up the four piece would stay in place and NOT get squished out. Patience IS a virtue. Tank care.
I got my gasket from napa and it came with four little plastic studs to hold it in place...I did everything like jacoby said above...I didn't use any silicone or anything and the whole job took about an hour.
BTW, you don't need to loosen or remove any motor mounts, the oil pan gasket should be rubber and flexible enough to work with it.
on
1 Post
Does this mean that you can remove the oil pan completely? I have an 86 that is leaking. I will replace the gasket in the spring when it is warm. Meaning if I can remove the pan, I might as well replace the pump and pick-up. I am sure if I DO use the 4 piece job that a lot of Gascacinch set-up will do the trick.
Thanks
Dave
Thanks
Dave
Thanks
Dave
I recently replaced the oil pan on my truck and it was not exactly easy, but it had an over sized drain plug in it that was stripped out and leaking.
You have to unbolt the motor mounts and raise the motor up. On my '94, I also had to unbolt the windshield wiper motor and bend a metal bracket on the back of the engine. Then I had to lift the engine with an engine hoist so I could pull the old pan out and work the new one in.
During all of this I found that the side inspection cover gasket was leaking and my motor mounts were shot. So a couple hour job turned into an all day project.
Yeah I was gonna order motor mounts as well. I am extremely familiar with the "Might As Well" jobs..
You have the motor up, "Might As Well" change the pan, "Might As Well" change the oil pump and pick-up. "Might As Well" change the tie rod ends since the tire is off. !!! I own two classic cars and the next thing you know the engine is at the machine shop!
