The unofficial Big Job thread.
#286
Maybe Big Job
I went out there and looked at the truck. The front end looks like a Big Job but, I'm not really sure. It has a very nice grill guard. It is the Coleman conversion. First one I've seen. It has SEVEN levers coming up from the floor. It has about a 40,000 lb. winch in the bed. It's pretty much all together. It has a monstrous power tower that is driven by the PTO and, in turn, drives the winch. It has a port in the roof so that you can see way up high when you're setting a pole. Tires have new tread but, a few surface cracks.
The last 2 are of my Ford.
#288
Question on the Big Job distributor
I'm not selling my F-900 Marmon Herrington.
BUT, I have a new problem. There are 2 steel tubes going from the distributor to the carburetor. One longer,, one shorter. Somewhere in the process, the steel tubes got bent badly.
I don't know which tube goes to which port. Does the longer tube go to the upper port on the distributor or,,, does it go to the lower port?
I have both the manual and, the parts book. I don't see it in the book.
Any help would be appreciated.
Dan
#289
#291
That Y-block looks pretty complete,,, at this moment. I wish I had it a year ago.
I just fired mine up yesterday. I only have short pipes. Boy, is it noisy.
I had to buy a crank and cam and lifters and pistons,,,, etc.
I posted a while back of a Big Job with a steel flatbed and 5th wheel hitch. The deal sounded good.
Reportedly, a rebuilt engine. I recently talked to the guy. He hasn't sold the truck yet. I told him that I would post his contact info here.
Jack in Escondido. seven six zero-717-1334
#292
Not a Big Job owner just yet. This weekend I may be going to take a look at a 51 F7 that is for sale. Assuming it's not a lost cause and getting it transported the 175 miles home doesn't cost as much as the truck I could be an owner soon.
Have a couple of questions for the Big Job owners.
What size socket should I bring with me for the crankshaft bolt on the 337? It's been sitting a long time, I want to check if the engine is seized.
Seller says its got a 5-Speed, not sure which though, if the shift pattern isn't indicated on the dash what's the next best way to determine if it's a direct or O/D? Is there a tag or casting number I can check if I crawl under it? The Clark transmission would be a 205 if direct and 205-VO if O/D correct?
Any other advice for what other things I should look for is appreciated also.
Thank You.
Thank You.
#293
F7's standard issue 5sp overdrive F8s standard issue 5sp direct however they could be ordered either way.
As far as sockets just bring your toolbox. Myself I'd bring a chain and tow it 5 or 10 feet in 3rd or 4th speed.
far as I know transmission model had a painted stencil left side probably long gone now cause the case is the
same just the gearing is different....
#294
#295
If it has the 332 engine then it likely has the Clark 265-V or 264-VO. Case markings for the 265-V are 5HDB, case markings for the 264-VO are 5HOB. Check the warranty plate - the transmission code for the 265-V is K, code for the 264-VO is J. That's assuming everything is original.
#296
#297
337 is the big flathead, and it's a monster compared to the standard 239's we're used to. Crank bolt head uses a 7/8 socket on the one I have.
The 337 was used through 1951. New engines were introduced in '52 based on the big Lincoln Y block, with a 279 OHV engine for the F7, and a 317 OHV for the F8.
#299
#300
Oh well, maybe next time.Sold before I could even make arrangements get up to look at it. Emailed the seller about it on Thursday night about looking at it this weekend. Didn't get a response now the listing is gone, maybe sold before I'd emailed?
Saved a screen shot and some pictures from the listing at least.
