torque specs?
Old Oct 19, 2007 | 09:40 PM
moto_stevo's Avatar
moto_stevo
torque specs?
Anyone know the torque specs for the tie rods on a 99 f-250 super duty?
I plan on replacing the inner and outer tie rods, on both the left and right sides. They are all REALLY loose.
Any advice on the replacement would be helpfull as well, since its the first time I've replaced tie rods on this truck.
Old Oct 19, 2007 | 10:48 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I only have data going back to a 2000MY but think it should be the same.
Tie rod ends get 67lbft, the steering adjuster sleeve clamps get 41lbsft. If you remove the tie rods, make sure to count the number of turns and replace the same way. You did not mention whether it was a 4x4 or not. A little more to it with that. Good luck.
Old Oct 20, 2007 | 10:37 AM
moto_stevo's Avatar
moto_stevo
Oh yeah, it IS 4X4.... What more work would that entail?
Old Oct 20, 2007 | 11:32 AM
Tenn01PSD350
Just the stabilizer or bumpsteer assembly if you plan on removing the tie rods as far as I know.
Old Oct 20, 2007 | 12:21 PM
Stewart_H's Avatar
Stewart_H
Yep, the same.
<TABLE width="95%"><TBODY><TR><TD>SECTION 211-03: Steering Linkage
</TD><TD align=right>1999 F-Super Duty 250-550 Workshop Manual
</TD></TR><TR><TD>REMOVAL AND INSTALLATION
</TD><TD align=right>Procedure revision date: 01/26/2000</TD></TR></TBODY></TABLE>
<HR>
Tie Rod End—Outer, RH, F-250, F-350, 4x4, and F-450, F-550
<META content="Tie Rod End—Outer, RH, F-250, F-350, 4x4, and F-450, F-550" name=tps_proctitle>
<TABLE cellSpacing=0 cellPadding=3 width="50%" border=1><CAPTION>Special Tool(s)</CAPTION><TBODY><TR vAlign=top><TD></TD><TD vAlign=top>Steering Arm Remover
211-003 (T64P-3590-F) or Equivalent</TD></TR></TBODY></TABLE>
Removal
NOTE: Replace the tie rod end if the ball stud is loose in the socket or the tie rod end is bent. Replace the front suspension steering ball stud dust seal if any nicks, cuts or tears are present. Do not attempt to straighten a bent toe rod end.
  1. Position and lock the wheels in the straight-forward position. Raise and support the vehicle; for additional information, refer to Section 100-02.
  1. Remove the wheel; for additional information, refer to Section 204-04.
  1. Loosen the adjusting sleeve clamps.
  1. Mark the steering damper position. Remove the nuts, washers, and two U-bolts. Position the steering damper out of the way.
  1. Remove the cotter pin and castellated nut. Discard the cotter pin.
  1. Disconnect and position the tie rod end (3A131) out of the way.
    • Use the Steering Arm Remover.
  1. Disconnect the tie rod end.
  1. Remove the tie rod end.
    • Note the number of turns required to remove the tie rod end.
  1. Remove the adjusting sleeve clamp.
Installation
  1. Follow the removal procedure in reverse order.
    • Install a new cotter pin.
  1. Check the toe-in and clear vision settings; for additional information, refer to Section 204-00.
Stewart
Old Oct 20, 2007 | 12:27 PM
Stewart_H's Avatar
Stewart_H
<HR>
Tie Rod End—Outer, LH, F-250, F-350, 4x4, and F-450, F-550
<META content="Tie Rod End—Outer, LH, F-250, F-350, 4x4, and F-450, F-550" name=tps_proctitle>
Removal
NOTE: Replace the tie rod end if the ball stud is loose in the socket or the tie rod end is bent. Replace the front suspension steering ball stud dust seal if any nicks, cuts or tears are present. Do not attempt to straighten a bent tie rod end.
  1. Loosen the adjusting sleeve clamp.
Installation
Stewart
Old Oct 20, 2007 | 12:34 PM
Stewart_H's Avatar
Stewart_H
<HR>
Tie Rod End—Inner, F-250, F-350, 4x4, and F-450, F-550
<META content="Tie Rod End—Inner, F-250, F-350, 4x4, and F-450, F-550" name=tps_proctitle>
Removal
NOTE: Replace the tie rod end (3A131) if the ball stud is loose in the socket or the tie rod end is bent. Replace the front suspension steering ball stud dust seal if any nicks, cuts or tears or present. Do not attempt to straighten a bent tie rod end.
  1. Remove the RH wheel; for additional information, refer to Section 204-04.
Installation
Hope those help.
Stewart
Old Oct 21, 2007 | 04:20 PM
moto_stevo's Avatar
moto_stevo
Thanks for the help guys. It went smoothly, with the exception of one tie rod outer end. I had to sawzall the nut off. The nut and tapered stud were both spinning in the hole. The big truck now steers and drives a whole lot better.
hhcobra
May 17, 2019 09:18 PM
bubbasz1
Feb 14, 2015 03:44 PM
MONAVIERONJON
Aug 18, 2014 12:37 PM
2-5-OH!
Jul 1, 2013 05:56 PM
Fishin76
Oct 29, 2010 12:52 PM
